Great news for the Global 7500...
Global 7500 Sets Bizjet Range Record...
Bombardier’s new Global 7500 this week achieved what the manufacturer is billing as the world’s longest flight by a purpose-built business jet. The aircraft logged 8,152 nm after taking off from Singapore at 7:12 a.m. local time on March 4 and landing in Tucson, Arizona, at 8:19 a.m.—setting a speed record for this sector in the process.
The aircraft landed with 4,300 pounds of fuel, falling well within NBAA requirements with nearly 90 additional minutes of flight time possible.
The Global 7500 entered service on December 20, 2018. Designed for long intercontinental flights, it boasts the industry’s largest business jet cabin and a maximum speed of Mach 0.925. This week’s flight exceeded the aircraft’s advertised range of 7,700 nm.
“The Global 7500 was built to break all the records,” commented Bombardier Business Aircraft president David Coleal. “It achieved the industry’s longest mission ever in business aviation after only two months in service. We’ve demonstrated its unequaled long-range and high-speed capabilities, but also its ability to break records confidently with healthy fuel reserves remaining, once again, confirming its unsurpassed performance to customers.”
Re: Great news for the Global 7500...
That is pretty incredible, my only question that arises from this is if corporate operators use “RP’s” / bunks?
Canadian regulations allow it for private operators. I’ll assume this plane was US registered. Does FAR part 91 (private operators) even have duty limits? I don’t think they do.
Extension of Flight Duty Period
[SOR/2018-269, s. 18]
604.101 If a flight crew is augmented by at least one flight crew member, if there is a balanced distribution of flight deck duty time and rest periods among the flight crew members, and if the next minimum rest period is at least equal to the length of the preceding flight duty period, the flight crew’s flight duty period may be extended
(a) to 17 hours with a maximum flight deck duty time of 12 hours, if a flight relief facility — seat is provided; and
(b) to 20 hours with a maximum flight deck duty time of 14 hours, if a flight relief facility — bunk is provided.
SOR/2014-131, s. 18; SOR/2018-269, s. 18.
EDIT: is that the actual picture of the airplane in the first post? If so it looks like a Canadian registration.
There's a closed off crew rest cabin at the front of the plane with a flat folding seat. It's the room just aft of the door:
We fly with augmented crews in the G550 quite frequently.
No duty time limits for Part 91 operationsvrrotate wrote: ↑Tue Mar 05, 2019 8:00 am Canadian regulations allow it for private operators. I’ll assume this plane was US registered. Does FAR part 91 (private operators) even have duty limits? I don’t think they do.
Correct... I find this still unbelievable in 2019.
For the Canadian duty to be extended fully, the onboard facility for the crew rest must conform to the newer standards with a lie flat seat...
Our Globals do not have this "lie flat" seat, so we cannot fully extend our duty day to the maximum allowable. We make crew changes as necessary if the passengers do not want to stop for 14 or 16 hours for crew rests.
interesting, thanks for the replies to give insight to the long haul corporate world.
It’s Canadian registered. There is only one demo machine so far and this is it.vrrotate wrote: ↑Tue Mar 05, 2019 8:00 am Canadian regulations allow it for private operators. I’ll assume this plane was US registered. Does FAR part 91 (private operators) even have duty limits? I don’t think they do.
Under what CARs subpart do experimental flight test aircraft operate? 702? 604? Is there some caveat in the 500 series CARs for this type of operation?
I'm genuinely curious.
This one is a fully certified production model. Of the 5 flight test planes only one had a production interior installed, the other 4 just had various engineering stations. I suppose they could have retrofitted them with bunks for the long duration flights though.goingnowherefast wrote: ↑Thu Mar 07, 2019 6:35 pm Under what CARs subpart do experimental flight test aircraft operate? 702? 604? Is there some caveat in the 500 series CARs for this type of operation?
Flight testing is covered under CAR 521.44 - 521.47. The aircraft would be on an Experimental Flight Test Permit.
702 wouldn't be appropriate because the aircraft is not for hire (no commercial air service). Probably cannot carry passengers under 507.04 so eventually I think it will be operated 604.Aircraft Information
Mark: C-FXAI
Common Name: Bombardier Model Name: BD-700-2A12
Serial No.: 70006
Basis for Eligibility for Registration: CAR Standard 507.04 (2) - Experimental Aircraft
My understanding is the first production aircraft (the one that broke the record) was delivered internally to the flight demo department at Bombardier. It is not an experimental aircraft.
If you want to get to the real nitty gritty, it was actually delivered to a leasing company and bombardier leases it back. So technically, it’s the first production aircraft delivered to a customer...Jet Jockey wrote: ↑Fri Mar 08, 2019 4:34 pm My understanding is the first production aircraft (the one that broke the record) was delivered internally to the flight demo department at Bombardier. It is not an experimental aircraft.
Yeah I knew it was something like that...wallypilot wrote: ↑Fri Mar 08, 2019 9:18 pmIf you want to get to the real nitty gritty, it was actually delivered to a leasing company and bombardier leases it back. So technically, it’s the first production aircraft delivered to a customer...Jet Jockey wrote: ↑Fri Mar 08, 2019 4:34 pm My understanding is the first production aircraft (the one that broke the record) was delivered internally to the flight demo department at Bombardier. It is not an experimental aircraft.
Anyway I'm very happy for the folks at Bombardier and glad to see they produced another fantastic aircraft!
I'm also very happy that guy at Bombardier ripped that Globe and Mail POS reporter.
