Hand swinging
Heliian
Hand swinging
Post by Heliian »
I'm glad someone is still capable of this but please be careful folks, luckily no one was injured.
http://www.cbc.ca/news/canada/saskatche ... -1.3012432
esp803
Re: Hand swinging
Post by esp803 »
10 meter take off roll :shock: and I thought an otter got off the ground fast....
E
Redneck_pilot86
Re: Hand swinging
Post by Redneck_pilot86 »
Well, without the pesky 200 lb pilot, the aircraft is pretty light....30 feet doesn't seem too unreasonable.
DonutHole
Re: Hand swinging
Post by DonutHole »
Poor fella
Canoehead
Re: Hand swinging
Post by Canoehead »
I'm reminded of this gem
http://youtu.be/AeTM-paAXCo
Re: Hand swinging
Canoehead wrote:I'm reminded of this gem
Make sure you have it on mute with Yakety Sax playing on a background tab. :lol:
lownslow
Re: Hand swinging
Post by lownslow »
I thought I was the only one who did this whenever I saw that video. For those who are thinking of trying, it synchs up wonderfully.
Pop n Fresh
Re: Hand swinging
Post by Pop n Fresh »
Oh my goodness, I just verbalized it and we were howling. Too funny!
ragbagflyer
Re: Hand swinging
Post by ragbagflyer »
This is what you do when you've had your airplane listed for a year or two and nobody has purchased it. :P
AirFrame
Re: Hand swinging
Post by AirFrame »
The CADOR is up for this incident... Good to see someone has a sense of humour...
CADOR wrote:The pilot of a privately registered Aeronca 11ACX on a local flight from Nipawin, SK (CYBU) successfully hand started the aircraft. However, the pilot did not have the opportunity to enter the aircraft prior to its departure from the runway. Subsequently, the aircraft crashed in a field adjacent to the runway. No souls on board. No impact to operations.
5x5
Re: Hand swinging
Post by 5x5 »
Guess the parking brakes on those skis aren't all that effective?
Mark Twain
Re: Hand swinging
When I used to handprop the old Champ on skis, the throttle was cracked open ever so slightly. Didn't have any problems. If it won't start and you get to the point of opening the throttle significantly, you need someone or something to restrain the aircraft.
praveen4143
Re: Hand swinging
Post by praveen4143 »
There's a very informative video on hand propping here - https://www.youtube.com/watch?v=qCqPtqvU9mg
Re: Hand swinging
praveen4143 wrote:There's a very informative video on hand propping here - https://www.youtube.com/watch?v=qCqPtqvU9mg
I have only gotten to 1:18 on the video and I am shaking my head at the stupidity shown. The video has started off as very informative in their explanation and there is now mention of the impulse coupling and how to tell if you have one. Simple he says by telling us to pull the prop through and listen for a loud click.
Then he walks in front of the aircraft in the hangar and pulls the prop through while leaning very close to it with his nose about 1 inch from the propeller arc(no need to be that close to hear a click in a quiet hangar) his hands wrapped around the prop much more than they need be.
It would have been best not to do this in a hangar but regardless of whether inside or out, he should have demonstrated to us that chocks are in, brakes set(if installed), mag switches off, throttle closed, throttle friction tight(if installed), mixture idle cutoff, and fuel selector off. Then turn the prop through from behind and only have finger tips pulling it through.
He may have done the securing portion of the items he listed but he sure didn't mention any of them. What if there is a live mag?
Be paranoid.
GyvAir
Re: Hand swinging
Post by GyvAir »
I agree; that was a little painful to watch. He did cover much of the safety precautions later in the video, after his initial demonstration of how not to do it.
I wonder how multiple raw chicken strikes would play into the ongoing argument over the interpretation of the various prop strike inspection SBs and ADs out there? Not a demo that I would volunteer any plane I had a vested interest in for!
Liquid Charlie
Re: Hand swinging
Post by Liquid Charlie »
Hand spanking aircraft was a way of life - my very first double registered letter was from starting a j-3 in front of the old brampton flying club. TC was sitting in a car just passing time -- fortunately it was one of the very few times I had a passenger with me and even more fortunate he was a pilot. At 16 years old a violation was a little scary -- haha --
Over the years I have hand spanked almost all the aircraft types I have flown with pistons. From a J-3 cub right up to a DC3 -- the worst were the fuel injected engines but with a little patience they too start well - secret - cold engine (not frozen but not hot from running) - worst was a norseman on floats and surprisingly the DC3 was pretty easy but needed 2 guys on the prop --
ACTPA :kriz:
Chuck Ellsworth
Re: Hand swinging
Post by Chuck Ellsworth »
a ski doo works real good. :mrgreen:
Liquid Charlie
Re: Hand swinging
Like this one . -- :smt040
ACTPA :kriz:
Re: Hand swinging
pelmet wrote: Sun Mar 29, 2015 1:03 pm When I used to handprop the old Champ on skis, the throttle was cracked open ever so slightly. Didn't have any problems. If it won't start and you get to the point of opening the throttle significantly, you need someone or something to restrain the aircraft.
C-GHNC, a private Cessna 172M, was en route to Thunder Bay (CYQT), ON. While in the vicinity
of Ignace (CJN3), ON, the pilot needed to make a stop in Ignace. The landing in Ignace was
uneventful. When the pilot returned to the aircraft, he was unable to start the engine. He exited the
aircraft and was able to successfully hand prop the aircraft. Once the engine started, the aircraft
began to move rapidly across the ramp and the pilot was unable to re-board the aircraft. The
aircraft traveled across the runway, crashed through a gate and caught fire. The aircraft was
substantially damaged.
It doesn't move rapidly unless the throttle is significantly forward of idle.
How about some chocks and brake if no tie down is nearby. At least brakes if no chocks or tiedown is available.
Re: Hand swinging
CAR 602.10 applies.
