Know when to say "No".
They may not have known
exactly what they were getting into (
based on previous experience success).
what happened to the other
You mean "128" .. the returned plane ?
The parameters of 128's flight are used for the investigation (TSB Report), so the person at the helm of this aircraft has played a very important part in establishing some investigative facts for this tragedy.
IMO this investigation could further use 128 to establish accurate airspeed at "event 1"
(ie: doublecheck it), just in case there is an error there. For example, what is the
IAS number (vs its groundspeed) at beginning of upset ... seeing "128" had claimed "5-10kts" airspeed drop by 4400ft where it turned-around 200ft before 127's 4600ft altitude at "event 1". It's possible "127" ("Nick") may have been losing more than 128's "5-10" in those extra 200ft of altitude if that loss was enhanced (ie: by any type of shear above 4400) just after "127's increase in climb rate"(report fact at ~4400)..which WAS immediately before "event 1" (above the "4400ft").
It appears via surface anaysis, that the LO on Superior ("991" on GFA) turns out deeper / stronger than advertised (30-40kts N-winds across Superior enhanced by 6degree water temps), 986hPa, so that northerly components are also stronger up there as far north as YPL. How are these CAS numbers in the report arrived at ?
