------------------------ Occurrence 1 ------------------------
Occurrence No.: A17A0087 Occurrence Type: INCIDENT REPORTABLE
Class: CLASS 5 Reportable Type: SMOKE OR FIRE (iii)
Date: 2017-12-24 Time: 15:14:00 UTC
Region of
Responsibility:
ATLANTIC
Country: CANADA Province: NEWFOUNDLAND AND
LABRADOR
Ground Injuries: Fatal: 0 Minor: 0
Serious: 0 Unknown: 0
---------- Aircraft 1 ----------
Registration: C-GGFP Operator: JAZZ AVIATION LP
Manufacturer: DE HAVILLAND Operator Type: COMMERCIAL
Model: DHC-8-400 CARS Sub Part: 705 - AIRLINER
Serious: 0 None: 43
Unknown: 0
Occurrence Summary:
C-GGFP, a Dash 8-402 aircraft operated by Jazz Aviation LP was conducting flight JZA8899 from
Goose Bay, NL (CYYR) to Halifax/Stanfield Intl., NS (CYHZ). During de-icing at CYYR, the de-ice
truck ran out of fluid. JZA8899 selected bleed air from the auxiliary power unit (APU) for heat, while
waiting for the truck to return. The APU ingested de-ice fluid, and the cabin filled with a blue haze.
The cabin crew advised the flight crew that they believed it may be a fire, and the captain ordered
a rapid deplanement. All passengers and crew excited the aircraft without injury, and were
escorted across the ramp to the terminal. ARFF responded to the aircraft.
The operator’s maintenance, completed a one hour ground run to ensure no residual deice fluid
was in the aircraft environment system, and the aircraft was returned to service.
Jazz APU ingested de-ice fluid, rapid deplanement
Re: Jazz APU ingested de-ice fluid, rapid deplanement
What is the difference between rapid deplanement and evacuation? Or is it the same thing?
Out the 1L door (air stairs) with pep-in-your-step, and should be without your carry-on bags. One convenience of a smaller aircraft without escape slides!
- rookiepilot
LOL.
I believe if they could get away with it, they'd configure the 777 etc as a one aisle aircraft.
This reason is why they can't.
Any MSDS sheet out there on the toxicity of deice fluid fumes in the cabin atmosphere?
