Last year I made reference to a Safety Alert For Operators(SAFO 15009) in this thread. It has very important information mentioning that landing distances in the aircraft performance manuals should be increased under certain conditions such as during moderate to heavy rain. Rockie was insistent that this SAFO was no longer applicable because it had pre-dated implementation of TALPA(even though it was still on the FAA website and even though an FAA inspector from the Air Carrier Division of the FAA confirmed to me that it was still applicable as seen earlier in this thread). In fact, this poster was giving you very bad information.
These are only some of the ridiculous responses that were given by him as his argument...
Rockie wrote: ↑Tue Aug 28, 2018 6:58 pm Check the dates on your documents versus the TALPA regulation implementation date Pelmet. The ones you're quoting are at least a year before the implementation of TALPA and do not even mention it.
Really...stop. Betraying yourself as a moron is not worth another pointless argument with me.
Or...continue. This should be good...
Rockie wrote: ↑Thu Aug 30, 2018 9:19 pm And each time you ask the same question over again despite getting the answer you betray how little you know about wet runways. Do I need to repeat the answer for a third (or was it fourth) time?
Your SAFO is older than the TALPA regulations that specifically address and amend landing distances higher for the very same reason they wrote that older SAFO to begin with.
Give it a few seconds real thought Pelmet and see if it dawns on you a little bit.
Rockie wrote: ↑Mon Sep 10, 2018 10:55 am We do not adhere to anything whatsoever contained in SAFO 15009 because it is old news and not relevant to our operation. If you continue to take issue with that I suggest you contact Transport Canada, the manufacturers and operators and take it up with them. In the meantime, I will continue to do what I am required to do despite your misguided opinion on this topic. As before, I strongly advise all other pilots do the same.
Here is what the FAA states in a current SAFO(19001)...
"The following ACs and Orders were revised or created in support of the TALPA ARC implementation:
1. AC 150/5200-30D, Airport Field Conditions Assessments and Winter operations
Safety
2. AC 150/5200-28F, Notices to Airmen (NOTAMs) for Airport Operators
3. AC 25-31, Takeoff Performance Data for Operations on Contaminated Runways
4. AC 25-32, Landing Performance Data for Time-of-Arrival Landing Performance
Assessments
5. AC 91-79a, Mitigating the Risks of a Runway Overrun Upon landing
6. FAA Order 7930.2R Notices to Airmen (NOTAMs)
7. FAA Order 8900.1 Volume 4 Chapter 3 Section 1 Safety Assurance System: Airplane
Performance Computation Rules, paragraph 4-494 Takeoff From a Runway which is
Wet or Contaminated, and paragraph 4-503 Landing Distances at the Time of Arrival.
8. SAFO 15009 Turbojet Braking Performance on Wet Runways"
Of course, I was correct the whole time and that SAFO 15009 was still valid at the time of our discussion(despite the other poster making an obvious and dangerous assumption that SAFO 15009 must have been cancelled based on its date of issue). However, SAFO 15009 was finally cancelled just this past month, more than two years after the implementation of TALPA and replaced with a new SAFO(19003) that states among other things....
"This SAFO cancels and replaces SAFO 15009 and warns airplane operators and pilots that the advisory data for wet runway landings may not provide a safe stopping margin especially in conditions of Moderate or Heavy Rain."
https://www.faa.gov/other_visit/aviatio ... O19003.pdf
...which is what I have been saying all along. The new SAFO still talks about the 30-40% additive in landing distance required in moderate to heavy rain. This can be accounted for by simply adjusting the TALPA runway condition code on your own(easily done at airlines using an onboard computer) because you may not get the proper condition code from other sources(ie. at the airport where you are landing).
Further info from the FAA from the SAFO.....
"The FAA recommends that airports report “Wet” conditions. However, airports are not required to report when a runway is only wet. Further, an airport may not be able to generate a Field Condition NOTAM (FICON) for sudden rain showers that result in water on the runway more than 1/8 of an inch in depth (contaminated)."
Folks.....Please beware of the information that you get on the internet. Insults do not make someone right. One can see further examples of this by the same poster on the thread about the AC Airbus that nearly landed on a taxiway last year. The same insults and bad information about how it is not proper to use the localizer to assist with aligning with the runway when in fact, the NTSB confirmed that it was a requirement to do so and that the failure not to do so was a primary cause of that incident. Obviously, this poster wasn't doing what was required in the same situation...…...bad info, quite possibly passed on to others flying said airline into SFO.
