Dear TSB - Flight Recorders are way too expensive
AirFrame
Re: Dear TSB - Flight Recorders are way too expensive
Post by AirFrame »
goingnowherefast wrote: Thu Dec 06, 2018 8:15 pmSame problem with avionics. Look at a home-built aircraft panel. Non certified avionics with huge screens, synthetic vision, the works. I bet that would have prevented some night CFIT or VFR into IMC accidents. A $10,000 non-certified panel is safer than the junk in most Cessnas, but probably costs about the same.
You don't have to bet, it's happened. A Lancair/Glasair owner, VFR on top of a thick cloud deck, suffered a total engine failure. He flew the video game down below the cloud deck and landed without incident... He was in the clouds for more than 10 minutes on descent... Never lost situational awareness, never lost control, ATC talked to him the whole way. He made course changes coming down as well. The system kept him advised of his gliding range, and he picked an airport rather early in the process that he could easily meet with reserve altitude. Broke out of the clouds only around 1000 AGL as I recall, and landed straight-in. He had a GoPro mounted on the rollbar and audio jacked in, the whole video was on YouTube when it happened.
Caveat: I think he had an autopilot as well, or at least a wing-leveller, that surely helped. Still, all of that in an Amateur-Built can be done for about $10K at time-of-build. Good luck getting a fully certified equivalent into a Cessna for twice that.
TimothysAr
Dear TSB Flight Recorders are way too expensive
Post by TimothysAr »
Most of the guys I know have cot convex onto type after initial test flight on their aerie. I think you have to be the owner for this to apply?
Cliff Jumper
Post by Cliff Jumper »
Good point, totally agree. I remember the first time i cot convex on type, and it wasn't even my aerie, it was someone else's.
