There was no recent third fatal accident, lllya kuryakin spreading more BS on this forum.
Air Tindi Flight Missing
Re: Air Tindi Flight Missing
- TheRealMcCoy
If you smoke and go fly 2 days later your blood work is going to come up as "high on drugs"...
Has anyone seen a picture of how badly the airplane was damaged yet?
That's not the impression I have:TheRealMcCoy wrote: ↑Thu Mar 07, 2019 7:21 pmIf you smoke and go fly 2 days later your blood work is going to come up as "high on drugs"...
From the TSB report
"Delta9-THC blood plasma concentrations in live subjects over 2 to 3 ng/ml have been shown to indicate marijuana smoking within 6 hours."
and
"Femoral blood contained 50.1 nanograms per millilitre (ng/ml) of delta9-tetrahydrocannabinol (delta9-THC), and 21.6 ng/ml of carboxy-THC. "
I'm surprised he could walk. The guy was so full of dope there must have been seeds and stems falling out from under his hat.
Anyway, that's neither here nor there. I would like to know what the third accident was.
There was that Caravan that had to put down on the lake a few years ago because it picked up so much ice that it couldn't fly anymore. That wasn't a fatal, though.
Pity you take it personally there, but was there not a Twin Otter accident not all that long ago. Caravan with the pilot doped out of his mind doesn’t speak volumes on company culture to you? Perhaps it should?Roadrunnersmother wrote: ↑Thu Mar 07, 2019 6:33 pmThere was no recent third fatal accident, lllya kuryakin spreading more BS on this forum.
Illya
I think you're confusing the Arctic Sunwest Twin Otter that crashed in yellowknife, not Tindi.Illya Kuryakin wrote: ↑Fri Mar 08, 2019 9:55 amPity you take it personally there, but was there not a Twin Otter accident not all that long ago. Caravan with the pilot doped out of his mind doesn’t speak volumes on company culture to you? Perhaps it should?Roadrunnersmother wrote: ↑Thu Mar 07, 2019 6:33 pmThere was no recent third fatal accident, lllya kuryakin spreading more BS on this forum.
Illya
- YYZSaabGuy
Maynard's correct. The third Air Tindi accident over the last few years did not, fortunately, involve any fatalities:
http://bst-tsb.gc.ca/eng/rapports-repor ... 4w0181.asp
The Arctic Sunwest accident, for those interested, is covered here: http://www.bst-tsb.gc.ca/eng/rapports-r ... 1w0144.asp
Wrong airline. I’ll buy that. Hardly qualifies as “spreading BS ....”. That’s just the friendly avcanada way.
https://www.cbc.ca/news/canada/north/ts ... -1.5117571
So they weren't below the minimum IFR altitude intentionally. Speculation was completely wrong.
- youhavecontrol
"According to Jeremy Warkentin, technical investigator for the TSB, one attitude indicator wasn't functioning when the flight took off, but the crew flew anyway. The second indicator failed 84 seconds before impact."
Oh geez
Oh geez
Did these guys have instrument ratings?
In the ground 84 seconds after no attitude indicators. Mind blowing they couldn't keep in air with rest of instrumentation.
Must be more to it than this. Basic altimeter and DG for straight and level in IMC will keep you alive.
Quite the training program this air tindi has.
That’s extremely disappointing to read.
I once had a vacuum pump fail, the CP wanted me to fly it to a maintenance base after the sun had already gone down. I told him no and after several back and forth and threats of firing me, I still said no. He hung up on me, then phoned back and demanded I be airborne the second the sun was up.
I flew the next morning, day vmc and guess what, the other vacuum pump quit 10 mins into my flight, one might wonder what the odds of that happening are. Pretty good if the cause is plugged filters and not mechanical failure. Needless to say, I made sure the CP knew he tried to kill me the night before, didn’t change him at all though, had several more run ins with him.
To this topic, it’s been awhile, anyone know if this aircraft had vacuum instruments?
I suspect when the AI fails in real life, it's a bit different from the instructor putting a post-it note over the AI. And the instrument rating flight test in Canada doesn't even test partial panel (although the IPC does).Roadrunnersmother wrote: ↑Tue Apr 30, 2019 5:33 pm Did these guys have instrument ratings?
- MarkyMark90
Sad to see this... Lost of both attitude indicator shouldn't lead an aircraft descend as a rocket to the ground...
It's a good reminder for all of us to challenge ourselves and keep asking us the question "What would I do if ..." while up there in the flight levels.
My dream is to fly... Over the rainbow, so high!!
How is it possible for the training industry and the regulator to allow the industry to have gotten to the stage where something like this can happen, assuming of course the latest info is correct?
Rumour on the street is that the FO instruments were steam driven and the captain’s were efis displays. Given that rumour, it’s possible that when the captain’s display failed, they might have had NO instruments, or just the very minimum standby instruments.
The other rumour, that bothers me greatly, is that the FO instruments had been faulty for some time. Not “discovered on the taxi out” of the accident flight. Supposedly crews had been complaining (snagging?) about them, but obviously to no avail.
Wouldn’t shock me to have Tindi vilify the crew when they likely pushed them out the door. After all, who wants to call Ekati at 7am to cancel or delay their crew change flight?
- Old fella
Lost an inverter climbing out of YDF dusk departure many years back, passed control over to right seat guy while I got inverter 2 up and going. Can’t remember how long that took but wx was decent , however if the right seat vacuum AI was u/s with a low vis and ceiling departure possibly would have made a few interesting moments for sure. I am not speculating on this particular accident though.
There but for the grace of God, go I.....trying to fly partial panel with instruments sort of working is difficult to the extreme. However this is why I am angry at TC that a 3rd AI, isn't required in SEIFR/MIFR airplanes in commercial service, and why they insist that we have a T+B, but I can'tput a G5 or equivalent with a battery backup.
