I agree that the drag goes down when the blades are coarser. It’s certainly true for a stopped prop, and a reasonable proposition for one that’s windmilling. I have to go and see if in a piston single with the throttle closed the prop control still affects the blade angle. I don’t know if it will come off the full fine stop at such a low rpm. But I’ll take ahramin’s word for it, until I get a chance to try it.pelmet wrote: ↑Sat Nov 07, 2020 6:23 amSo you agree that selecting full coarse on the blades on a windmilling prop will increase the glide distance.photofly wrote: ↑Sat Nov 07, 2020 6:21 amI agree with that. (There’s nothing really very complicated about looking at the aerodynamic forces on a propeller blade).pelmet wrote: ↑Sat Nov 07, 2020 6:09 am
I think that you may have come to a conclusion and are now coming up with complicated ideas to back up the conclusion. I suggest testing it out on an appropriate aircraft and then get back to us with the results.
Even NTS and Beta Follow-up are designed to coarsen blades to reduce drag on certain turboprop engines. The coarser the prop, the less the drag.
Nevertheless, a rotating prop should not be thought of as generating force by “flat plate area”: look at the braking effect of a “discing” prop due to negative blade AoA. The rotation of the blade makes a big difference when compared to the drag generated by a stationary one. I would not trust reasoning based on “flat plate area” even if the conclusion is correct.
Even with a stationary blade, airplane drag is not due to “flat plate area” but due to the blade being stalled (with the opposite sign of AoA to when it is turning and producing thrust, but it’s still stalled.) As the stationary blade turns coarse, its AoA decreases, and it unstalls, decreasing drag. A feathered prop is one with zero AoA: least drag.
I’m not sure about the throttle position: intuition says opening the throttle will decrease the resistance to turning the prop, increasing the windmilling speed and absorbing more energy from the aircraft, which is not what you want. My intuition is usually pretty good, so if you have reason to understand the opposite, I’d like to hear it. It’s a harder experiment to carry out, because with a functioning engine opening the throttle will provide power. I guess one could experiment with the magnetos shut off.
