C150 down by Jasper 1 fatality, 1 injured
https://www.cbc.ca/news/canada/edmonton ... -1.5219705
Condolences to family, best wishes on recovery
Re: C150 down by Jasper 1 fatality, 1 injured
C-GCEA, a Cessna 150J, was on a VFR flight itinerary from the Jasper Airport (CYJA) to Hinton,
AB with one pilot and one passenger on board. Shortly after take-off the aircraft entered a
departure stall and spin to the left. The aircraft impacted the Athabasca River approximately 0.5
nm from the departure end of the runway. The pilot sustained serious injuries and the passenger
was fatally injured. The 121.5 Mhz ELT activated. Witnesses on Highway 16 were able to attend to
both occupants within minutes of the accident.
Sounds like another stall/spin scenario due to improper flight technique....
http://www.bst-tsb.gc.ca/eng/enquetes-i ... W0095.html
Unstated in the TSB report is the interval of the 19 mph groundspeed decrease. Possibilities include slowly increasing pitch until spin onset (possibly to counter sink in a performance challenged aircraft in the conditions) or a sudden windshear. However a windshear decreasing groundspeed suggests increased headwind.Just before the loss of control, the GPS (global positioning system) recorded a reduction in ground speed from 83 mph to 64 mph and a course change approximately 30 degrees to the left of the runway track. During the reduction in airspeed, the altitude remained constant at about 150 feet above ground level for almost 5 seconds before the aircraft departed controlled flight and entered the aerodynamic stall and left-hand spin.
Wow, by the looks of the wreckage, its a wonder anybody was able to survive that, I wonder if they mistook the river for a runway? Is this a new sign of how bad newer pilots have become
Whats up with all the advertising anyway?
- rookiepilot
You're really amusing. Not.
Do you actually read anything before you comment, or is that a lost skill?
Wow, 100 LL hasn’t even leached into the ground and here you are postulating once again. Don’t you have a “ready room” to go back and draft your next sensational thread title on some poor sod? All this under the guise of aviation safety?!?pelmet wrote: ↑Wed Dec 18, 2019 7:46 am Sounds like another stall/spin scenario due to improper flight technique....
Accident happened almost 5 months ago actually, and we now have much more information from the TSB, so your statement, as usual, is wrong. No surprise about that of course, but I would suggest that the poor sod is the dead passenger. However, to each his own.TeePeeCreeper wrote: ↑Wed Dec 18, 2019 10:42 pmWow, 100 LL hasn’t even leached into the ground and here you are postulating once again. Don’t you have a “ready room” to go back and draft your next sensational thread title on some poor sod? All this under the guise of aviation safety?!?pelmet wrote: ↑Wed Dec 18, 2019 7:46 am Sounds like another stall/spin scenario due to improper flight technique....
As for the aircraft, no engine malfunction identified and good flight controls, light winds, high density altitude, probably close to max takeoff weight, in a turn.
Class 5 investigation according to the TSB which in part says.....
"A class 5 occurrence has little likelihood of identifying new safety lessons that will advance transportation safety."
I think most can figure out why. PM me if you need further assistance.
