No bounce landing
Re: No bounce landing
Not sure I can see the nose gear. Maybe shutoff engines, and didn’t feather because props would “dig”. Also takes quite a while for some engines to feather to stop
So there’s no nose gear...
Then the pilot shuts off both engines (to avoid prop damage) but then decides NOT to feather them - so they keep turning and will inevitably be damaged, then fucks up the approach, impacts soft ground prior to the threshold with no flare, and rips off the main gear too.
I’m trying really hard to construct a narrative where a pilot flying regularly for an airline ends up reasonably or understandably with this result.
Or, maybe he tried, yet forgot the part of the flight manual on page 2-4 where it says:Then the pilot shuts off both engines (to avoid prop damage) but then decides NOT to feather them
"A feathering lock, operated by centrifugal force, prevents feathering during engine shutdown, making it impossible to feather any time the engine speed is less than 800 RPM. For this reason if the engine is being feathered to save it the pilot must be sure to move the control to the feather position before the engine speed drops below 800 RPM"
This is common to many Lycoming powered twins, you gotta know your systems! Feather it/them early on, and if the engine has stopped because of seizure, you're not going to get it feathered. I did the testing on the DA-42-L360.
If the pilot was staggering the plane down the approach at a silly slow speed, and shut down the engines in fine pitch, they probably slowed to less than 800 RPM right away, the he got the surprise of his life when they would not feather, and he could not figure out why - further adding drag to an already horrible approach. But.... I'm just speculating!
It looks like a stall, way too slow and nose attitude, only my opinion.
I don’t agree. The aircraft pitch was pretty much level, which, combined with a reasonable flight path angle, gives a moderate (not high) angle of attack.
Thats a total load of crap ! You are ignorantly looking at the A/C attitude relative to the runway plane ! The AOA is the approach path angle RELATIVE to the aircraft WIKI
THAT angle in the video was high due to windmilling props, gear down etc. IF the pilot tried to flare , too high, the consequences may have been broken backs ! Its possible that the only right thing the pilot(s) did was to not flare lolthe angle between the chord of an airfoil and the direction of the surrounding undisturbed flow of gas or liquid.
Would 2 experienced pilots be sooo ignorant as to stall the plane throughout the final approach ? There was no concerted pitch up to produce a quality stall in the sequence!It looks like a stall, way too slow and nose attitude, only my opinion.
Possible scenario ( and I think DAR is right on ! ) Pilots were aghast at the props not feathering and the extra drag compelled them to approach at a very minimum speed above stall, to get to the runway, leaving them with little choice but to basically "drive her on" !
Or to paraphrase:corethatthermal wrote: ↑Sat Dec 14, 2019 7:37 pm I don’t agree. The aircraft pitch was pretty much level, which, combined with a reasonable flight path angle, gives a moderate (not high) angle of attack.
Thats a total load of crap ! You are ignorantly looking at the A/C attitude relative to the runway plane ! The AOA is the approach path angle RELATIVE to the aircraft WIKIthe angle between the chord of an airfoil and the direction of the surrounding undisturbed flow of gas or liquid.
"You're wrong because you are right!"
Your underlined quote literally says he is comparing the level attitude with a reasonable flight path angle.
You can argue if the flight path angle was reasonable, or that the aircraft pitch was level, it was a crappy video anyway, but I do not think the definition of angle of attack is a point of disagreement...
The FPA and AOA are relevant due to its "low energy state" high drag, steep approach and no thrust/overwing airflow to compensate !
Not so digits ,
I spoke about the backside in previous posts and got a load of shaming ! You kids cannot even understand the front side of the power curve!!
The aircraft pitch was level, yes, with the runway !......I don’t agree. The aircraft pitch was pretty much level, which, combined with a reasonable flight path angle, gives a moderate (not high) angle of attack.
NO, the nose should have been much lower, generating a much higher airspeed BECAUSE it would take the airspeed to trade off for pitch change in the flare and g-load and drag to accomplish a safe landing !reasonable flight path angle
Probably only DAR has done tests WRT windmilling props and its effect on this site, but can YOU imagine the loss of lift over the affected area(s) COMPARED to an increased airflow velocity and lift due to the positive prop slipstream effect ?
Exactly! It gives me the shivers to see planes flown in very low energy, for exactly the reason seen in that video. If you must, you must, but you have to know that an engine failure, and worse the drag of windmilling prop(s) shortly after are going to be a terrible surprise. 'Same thing for needless steep climbouts. If it quits, it will, at best, end up like that landing.NO, the nose should have been much lower, generating a much higher airspeed BECAUSE it would take the airspeed to trade off for pitch change in the flare and g-load and drag to accomplish a safe landing !
Pilots should practice power off landings more, and the realities of gliding would be better understood. But, practice with your hand on the throttle of running engine(s), in case you need a burst of power to prevent exactly what this pilot seemingly could not prevent.
For anyone fortunate to be able to fly/ride in a Cessna Caravan, when circumstances are ideal, and there are no passengers to alarm, set the plane in a nice glide way up high, get it all trimmed out on speed, leave the engine at idle, and gently feather the prop. It's like a magnificent push from behind, as the drag reduces. The PT-6 does not mind idling a feathered prop in flight. You'll really get a sense of how much drag a windmilling prop creates!
I'm amazed that the occupants exited without injured backs!
DAR, you have called me out when I have erred and you have responded when what was printed was evident to be truth ! I have never had the opportunity to thank a person of integrity as you ! Thanks ! and please keep up the good work of educating both the beginners and reminding the experienced of all that is aviation !
When following posts here I regularly wait with anticipation for WDDT (What Does DAR Think) to happen!corethatthermal wrote: ↑Sat Dec 14, 2019 11:23 pm DAR, you have called me out when I have erred and you have responded when what was printed was evident to be truth ! I have never had the opportunity to thank a person of integrity as you ! Thanks ! and please keep up the good work of educating both the beginners and reminding the experienced of all that is aviation !
I did some analysis of the video, and it looks like the aircraft was pretty much stalled on final approach.
I extracted five frames at -2 seconds, -1.5 seconds, -1 second, -0.5 seconds and at impact, and rotated and superimposed them to match the horizons: Then I was able to create a composite of the aircraft position, and make measurements of the apparent flight path angle. To allow for foreshortening I compared the vertical and horizontal sizes of the aircraft, which I believe is a Piper Seneca.
The angle of the video is shot from about 38 degrees off the nose of the aircraft (changing as the aircraft moves, but only a little.)
I estimate the actual flight path angle to be close to 19°, which is pretty darn steep.
Two seconds before impact the aircraft appears to be about 7m from the ground, giving a rate of descent of about 600fpm. If actually descending at 19° to the horizontal the forward velocity would be 20.3m/s and the airspeed 21.5m/s, or only about 42 knots.
All three gear legs appear to be down:
How about you understand what is posted?corethatthermal wrote: ↑Sat Dec 14, 2019 8:57 pm
If your pitch is 0, and your flight path angle is reasonable, let's say between 3-6degrees, it is highly unlikely you are stalled. An average wing stalls around 14-16 degrees. In the above described situation, you are nowhere near that.The aircraft pitch was pretty much level, which, combined with a reasonable flight path angle, gives a moderate (not high) angle of attack.
If you don't agree with the premises (which I didn't), then attack that. Don't act as if you are the only one who has ever heard about an AoA just because you can't understand what was written. Nobody is disagreeing with the definition of AoA.
From playing around with the Seneca and the Cherokee six, with power off, yet engine still generating power as opposed to a windmilling prop, holding the stick full back put the airplane into a mush attitude where exactly the same descent results and profile. The hershey bar wing really only does a hard nose drop stall if you force it to. I had wondered if this resulted in a survivable crash profile, for the most unskilled of pilots to just get it back on the ground and have a good chance of living. Looks like these guys put that theory to use.Two seconds before impact the aircraft appears to be about 7m from the ground, giving a rate of descent of about 600fpm.
That is excellent Photofly! You've quantified a maneuver which looked bad, as being bad by numbers we recognize.
A concept to remember is that from a stable descent (which this was), it's necessary to add energy to the flight, to arrest the descent (accelerate up from the descending flight path). To have energy to add, you have to have it either as thrust available (not in this case apparently), or a reserve of airspeed, which you may spend to flare. This pilot created a very steep descent path, so much more energy would have been required to flare. And... add to that, that as one pulls to accelerate up from the steep descent path, you might be actually pulling a small amount of G. When you pull G, your stall speed increases, so if you were just about to stall, now you just did, and accelerating up is no longer possible. This video shows that happening.
I opine that it's possible during this event, the pilot probably did pull to flare at the last moment (who of us wouldn't!), and nothing happened, it just kept going down.
Transport Canada once asked me to demonstrate compliance with engine failures from 50 feet in a modified Grand Caravan at gross weight, at a specified speed slower than the 87 knots Cessna states for climb speed after becoming airborne. That was the most un nerving testing I've ever done. I'd get to the point of flaring, and there was nothing left when I pulled. I did not slam the plane on, but I admit to adding a whole bunch of power to cushion the touchdown each time. TC and I agreed with the test outcome, and a fair compromise was made for the approval, but right then and there, I learned why we should carry a reserve of speed anywhere near the surface. This video, and Photofly's super analysis show us why too!
Thanks for the vote of confidence, and I still have lots to learn too! I just know the things I have learned so far, and try to pass them along in the interest of safety. Recently, when I hear of accidents, I ask myself what I could have contributed back to our industry which might have prevented that event. So, I'll speak up.....I regularly wait with anticipation for WDDT (What Does DAR Think) to happen!
I stand corrected wrt the nosegear(all you video wizzes out there) however look at the damage to the props afterward. Now I'm not an acccident investigater, but it looks like there was no power to the prop( blades bent in middle, no rotational damage) does someone who does this for a livving want to chime in
Ok. This is super cool. CSI muchphotofly wrote: ↑Sun Dec 15, 2019 8:43 am I did some analysis of the video, and it looks like the aircraft was pretty much stalled on final approach.
The average vertical speed seems to be 700 fpm. Is that enough to break a landing gear though?
Maybe pilotDAR can chime in here. What is the minimum vertical speed a landing gear needs to be able to withstand upon touchdown for certification?
If memory serves (and it might not) from previous sim sessions, I believe gear damage on transport category jets was not an issue under 700 fpm touchdown. Granted, big planes, but if anything, smaller planes have much less inertia, so they should be more resilient. Makes me wonder if anything else was wrong that the gear literally flew off on this hard touchdown.
700fpm is about 3.5 m/s. How long did it take for the vertical speed to reach 0 here? 0.1 of a second would make it 3.6G touchdown. I don’t know if gear breaks at that point but that’s some serious load on the structure.digits_ wrote: ↑Sun Dec 15, 2019 10:36 amOk. This is super cool. CSI muchphotofly wrote: ↑Sun Dec 15, 2019 8:43 am I did some analysis of the video, and it looks like the aircraft was pretty much stalled on final approach.
