India - King Air B200 crash caught on video March 27/2014
Aviation Safety Network info on the March 27 crash - all 9 persons on board survive.
Video posted on LiveLeak
- Rank Moderator
Re: India - King Air B200 crash caught on video March 27/201
Looks like they had an engine failure just after rotation?
Happiness is V1 at Thompson!
That was well handled! I'm glad nobody was killed.
Bad timing on that pt-6's part.
- Brantford Beech Boy
attempted to re-land?
how do you yaw towards the live engine?
BBB
BBB
Retard! Retard!
"how do you yaw towards the live engine?"
Simple. You yank back both power levers just as the failed engine auto feathers suddenly giving you way more drag on the healthy side. I could nt really tell what happened tho, except that it went badly..
but yanking both pwr levers to idle would cancel the autofeather...somewhat equalizing the drag....still a bad scene
good video to teach why u should continue once past v1....
BBB
BBB
Not if the auto feather sequence had started.Brantford Beech Boy wrote:but yanking both pwr levers to idle would cancel the autofeather...somewhat equalizing the drag....still a bad scene
BBB
Pretty lucky nobody died in this one.
Illya
Torque runaway on RH side. Pilot thought LH had failed, pulled on both and RH kept going and got overwhelmed?? just a thought.
That's why sim training is important kids!!
Overweight takeoff?
What makes you think that?
Accident speculation:
the right prop feathering as the nose lifts off...
and @ilya, the beech afx system does not "latch" like a basler or others...
retarding the pwr levers will cancel an afx...
bbb
bbb
- Rank Moderator
Dunno, I just glanced at it...rotation, airborne, yaw to the left, and thump! Fully ready to be corrected, or learn more...trey kule wrote:What makes you think that?
I'll wager the pilot stepped on the wrong rudder. That would cause a yaw into the good engine.
Chase lifestyle not metal.
Think one could overpower the Rudder Boost?I'll wager the pilot stepped on the wrong rudder. That would cause a yaw into the good engine.
- cdnpilot77
Pretty easy if the rudder boost system wasnt engaged prior to takeoff. Finley wrote:Think one could overpower the Rudder Boost?I'll wager the pilot stepped on the wrong rudder. That would cause a yaw into the good engine.
Can't see stepping on the wrong rudder. You'll have the urge to get your knee out of your teeth, and that's the correct rudder.cdnpilot77 wrote:Pretty easy if the rudder boost system wasnt engaged prior to takeoff. Finley wrote:Think one could overpower the Rudder Boost?I'll wager the pilot stepped on the wrong rudder. That would cause a yaw into the good engine.
Illya
It's been a while, but it thought the rudder boost system was a function of oil pressure?cdnpilot77 wrote:
I don't recall a rudder boost 'switch'.
Furthermore, I'm certain that you could easily overpower it.
- cdnpilot77
It's Pneumatic....it wouldn't let me cut and paste so here is the quickest easiest link I could find.Canoehead wrote:It's been a while, but it thought the rudder boost system was a function of oil pressure?cdnpilot77 wrote:
http://www.mrmoo.net/pilot/BE200/Older% ... ntrols.pdf
