Digital Artificial Horizon
Moderators: North Shore, ahramin, sky's the limit, sepia, Sulako, Rudder Bug
tazin river
Re: Digital Artificial Horizon
Post by tazin river »
If I wanted to get rid of the vacuum pump, DG and AH altogether, would I need to get two Garmin G5 units (one showing AH and one used as DG) or is one enough toggling back and forth as needed?
Tips Up
Post by Tips Up »
tazin river wrote:
Wed Feb 20, 2019 8:28 am
When I looked into it a year ago to ditch vacuum system, the G5 wouldn’t suffice to date. Not certified as a stand alone back up. Can be used as a primary but to ditch the vacuum one would need the G5 or G500 etc as a primary and for the back up something like the Sandia SAI 340.
rigpiggy
Post by rigpiggy »
Avidynes E5 is now available for same price as the G5. Put the AH where the vsi is, and should be gtg
rigpiggy
Post by rigpiggy »
TimothysAr
Post by TimothysAr »
I set my horizon occasionally to reflect level flight in my current state of trim depending on load. Id expect to do the same with a digital instrument. And what does icing have to do with any horizon instrument?
rigpiggy
Post by rigpiggy »
Just what Garmin certified no fiki, not more than6000#, not more than 6people, methinks it is so they can sell you a more expensive system
There’s no requirement for a vacuum system or AI/DG in a day VFR aircraft at all. Not even a turn and bank indicator.
Personally I’d think putting one G5 in is better than two vacuum instruments. The G5 has a backup battery which will get you out of almost any situation you got yourself into, and displays information much better than an AI.
AirFrame
Post by AirFrame »
C-GKNT wrote:
Fri May 06, 2016 8:50 am
See my previous post. With the Dynon like the Garmin G500/600/1000, no GPS--->No Attitude.
The Dynon D10A doesn't require GPS for attitude.
tazin river
We installed the G5 last week and used it for the first time a couple days ago...
...I think I am going to really like this instrument....simple and easy to use...
