Cold weather oil indications
rigpiggy
Post by rigpiggy »
We had some issues with oil press indications in the cold, the first guy i flew with had several 206/185s. He used to fill the oil pressure tube with hydraulic fluid every fall.
I gots to tell ya it works like a hot damn, oil pressure within seconds, ask your ame if you have similar issues
valleyboy
Re: Cold weather oil indications
Post by valleyboy »
The good old days -- mention that now and most AME's will look at you if you had 2 heads -- simply put in this day of CYA, it's not legal. I wonder if external gauges mounted on the cowls is an approved mod :mrgreen:
http://www.blackair.ca
SuperchargedRS
Post by SuperchargedRS »
rigpiggy wrote: Wed Jan 31, 2018 11:41 pm We had some issues with oil press indications in the cold, the first guy i flew with had several 206/185s. He used to fill the oil pressure tube with hydraulic fluid every fall.
What kind of temps are we talking here?
I've had my 185 out to about -28c and never had that issue
valleyboy
Post by valleyboy »
It usually happens with a cold soaked aircraft (stored outside and plugged in) between -30 and -40 (40 being the cut off point) - no problems with a hangared aircraft. The issue a lot of the times was to get oil pressure indication for the initial start in the morning or after sitting for a couple hours with raps on.
Heliian
Post by Heliian »
Oil pressure should come alive withing 30 seconds of start.
J31
Post by J31 »
Flew lots of 185, 206, 207 down to -40 and rarely any problems with multi-grade oils. However we did clean the oil lines out with varsol if there were problems. This would introduce fresh engine oil in the lines.
rigpiggy
Post by rigpiggy »
The oil theat was pumped out of the lines in the hangar could only be decribed as "grease"
rigpiggy
Post by rigpiggy »
That and we are in a twin. The oil lines are about 8' long, all but about 2' is in unheated spaces
