Vazar Otter external load LSTC
ragbagflyer
Post by ragbagflyer »
Hello, does anybody know of any external load LSTCs to allow carrying 3 canoes on a Vazar Otter at 9000 pounds?
Heliian
Re: Vazar Otter external load LSTC
Post by Heliian »
If it's an LSTC then it'll be whomever owns the aircraft as they are aircraft specific.
ragbagflyer
Heliian wrote: Wed May 01, 2019 4:14 am If it's an LSTC then it'll be whomever owns the aircraft as they are aircraft specific.
They're almost exclusively LSTC's, but the owner or the LSTC can sell the data and a DAR can submit an application to copy the existing LSTC and have it issued to a different registration.
Heliian
Post by Heliian »
ragbagflyer wrote: Sat May 04, 2019 10:00 am
Have you tried air sag or any of the Quebec operators?
phillyfan
Post by phillyfan »
Nesting Canoes is one possibility. I assume that since you are looking for something as specific as a 3 canoe STC, that its something you need to do fairly often? We use to haul 3 nesting Canoes on each side. I do have an LSTC that references dimensions rather then specific numbers of canoes or boats. I am sure you could strap a couple canoes together and it would fall within the dimensions? PM me if you need more info.
