Gee - all that for me? I'm touched.... Maybe you assume that I am a relic standing here with a double bladed axe quinting at all this new fangled technology with great suspicion. I actually work in the aviation industry on the latest and greatest bits out there - and therefore my disbelief that these great improvements are the cure all. I have a suspicion that what they are providing is great results on the fiscal bottom line, but not necessarily the greatest results in the real world. But then you know much better than I what the situation really is by your position. As I have learned through my many years in the industry, technological advances sometimes are foisted upon us to keep the illusion that things are improving. I sure wish I could believe you.iflyforpie wrote:No... they were created by people and used by people who are on the ground and in the air around fires to classify fire behaviour and prevent the loss of equipment, values, and lives like was so common back in 'the good old days'.... and to determine the correct course of action--which will probably be sending air tankers in to a particularly nasty one.Dibbley wrote:Maybe I'm from the old school but I assume that fires have not changed that much - these ranking systems sound like the creation of the modern era and office dwellers.iflyforpie wrote:Yes, it might be able to smother some smoldering Rank 1 in the middle of nowhere and no further action will be required..... but you will never see a Rank 3 or higher interface fire actioned by a Mars and nothing else and have a successful outcome.
Nice try though....
That's why I said....There is never the claim made that aircraft support is the end all, but I do hope before you put the ground crews in, an effort is made to knock back the inferno with a credible air response,so their jobs are safe to do.They still don't put out fires.The tankers buy you time.
No... it's simply progress.... compared to the massive clusterfucks of yesteryear, fire management has improved tremendously. In fact... IMHO it's too efficient. It's only those who feel their livelihoods or positions threatened that are attacking it.It does sound like the accountants and ministry folk are calling the shots these days, and therefore the positive media spin to justify the use of these fancy agplanes.
Finally.... sometimes there is nothing you can do to stop a fire. I saw it first-hand in '03 in the Okanagan. Maybe they could have nipped it in the bud with an early morning run and a rap crew.... but Okanagan Mountain Park was a tinder box that would have simply gone up at another time.
It's interesting to note that most of the recommendations for reducing these interface fires... like controlled burns, reducing fuels, and making permanent fire guards around municipalities as recommended in the wake of Okanagan Mountain Park... haven't been implemented.
Petition To Save The Mars.
Re: Petition To Save The Mars.
You better move over Cat apparently you are being replaced!!
- Cat Driver
I was replaced many years ago in the water bombing game, in fact the last year I flew the scoopers was 1985.You better move over Cat apparently you are being replaced!!
I do enjoy reading about how far advanced fire suppression has evolved though since the era I flew them.
As to fire suppression using airplanes back in the time when physics were just being figured out we thought that delivering water to a fire every three minutes or less was effective in dropping the temperature of the fire and it seemed to put the fire down......but maybe I was just imagining it because I thought it was effective.
Water scoopers deliver water at an average rate of twenty loads per hour.......however when we used fire retardant only the load delivery took a lot longer...
...for sure accuracy in the drop was very important and if a crew missed their drop and had to fly back to the airport and get another load the effectiveness of a fire bomber was greatly reduced.
Are these new crews just better pilots and they never miss a drop?
The closer the water the better scoopers work. Unfortunately there are large sections of Western Canada where there are no scoopable water sources anywhere close to the fires. For these situations retardant is the only option.
The best scenario is when you can use both scoopers and retardant bombers at the same time. The retardant can limit the spread of the fire while the scoopers keep the fire down until it gets cooler and/or the ground crew put it out.
One advantage of the Fireboss over the Cl 415 is that they can be dispatched to the fire with a load of retardant, lay a line down along the edge of the fire and then switch to water drops right on the fire.
- Cat Driver
I thought the 415 has a cam lock connection for loading long term at airports.....the PBY's did and we often started the fire action with long term.....if water was close to the fire we scooped, if not we were land based tankers and kept returning to the airport for long term.
One good thing about my time as an air attack pilot I was hired as a direct entry Captain and trained by one of the best in the business before I went all on my own.
However I did have to spend a lot of time in the right hand seat over the years when doing training.
I can't wait to get old so I can tell anyone younger than me how much better I am. You guys crack me up! Ha Ha!
- Cat Driver
Reading your posts from the past if I were you I would be more worried about being able to afford to fly as long as some of us did the way the industry pilot pay is headed.I can't wait to get old so I can tell anyone younger than me how much better I am. You guys crack me up! Ha Ha!
Yup... for sure if I were flying for an airline these days I would forget about the generation that has retired and worry about the low cost low pay trend that is gathering speed.
