Cleaning Fouled Plugs
Post by ahramin » Tue Apr 02, 2019 10:06 pm
I've got a couple plugs here that are almost dripping oil. I'm guessing that if I try to put them in the spark plug cleaner with this much oil I'm going to end up with a slurry of cleaning abrasive and oil. Is there a solvent that's ok to use? I can't find anything on the Champion or Tempest websites.
Heliian
Re: Cleaning Fouled Plugs
Post by Heliian » Wed Apr 03, 2019 4:12 am
Contact cleaner.
Pacqing
Post by Pacqing » Wed Apr 03, 2019 6:14 am
Don't overthink it, just clean them, use contact cleaner or princess aviation brake cleaner.
corethatthermal
Post by corethatthermal » Wed Apr 03, 2019 7:56 am
Paint thinner, gasoline, pretty much anything spark plugs are pretty tolerant !
Post by ahramin » Wed Apr 03, 2019 10:50 am
Thank you.
JasonE
Post by JasonE » Thu Apr 11, 2019 2:41 pm
I love picking the lead out of C65/C85 plugs :)
Post by iflyforpie » Fri Apr 12, 2019 4:34 pm
Contact cleaner or brake cleaner and a good blast of shop air.
You're right that it will create a slurry if you don't get the oil out first.
Hopefully it isn't indicative of more serious problems.
Return to “Maintenance”
