Quick drain oil valve
tazin river
Post by tazin river »
You guys know of a special method to drain the oil out of a continental engine on a Cessna 180 Without removing the cowling and not make a mess? It has a quick drain valve.
JasonE
Re: Quick drain oil valve
Post by JasonE »
I am not familiar with your particular configuration, but on my Cherokee I was able to make an adapter that locked onto my quick release with a long tube to drain into a bucket.
broken_slinky
Post by broken_slinky »
Mine has a 1/4 turn quick drain valve on it. A piece of 3/8" clear plastic tubing fits on it slightly snug. When the engine is hot, it slips over easier and sort of seals itself on. I wear a pair of gloves and just reach in next to the exhaust and slip it on. 9/10 times I get it connected without making a mess.
Princess Auto sells a 10' roll really cheap. I don't even bother saving it for the next oil change to ensure it stays clean to pull the oil sample.
tazin river
Just ordered some from Princess auto. Will try this.
Return to “Maintenance”
