Hi, I’m wondering how much would it cost to replace an existing small efis ( dynon ) instrument with a new one in the same spot . What do avionics shops charge nowadays?
How much to install new instrument
if you are on the ground I guess there is now way but to look up!
Re: How much to install new instrument
How long is a piece of string?
Roughly 95-125 CAD/hour + tax
Just do it yourself! How hard can it be? The hole is already there, so just fill it with the new box. If you’re really lucky, the wiring harness from the old one will fit the new, so you can probably be done in about 30 minutes.
