It’s not important to learn on steam gauges vs. glass. It’s important to learn with as few as possible instruments, the better to avoid them getting in the way of understanding how an aircraft flies.ahramin wrote: ↑Fri Jun 29, 2018 9:46 amA good point photofly. My comments are based on my own experience as a student and my experience teaching pilots who learned to fly on both steam gauges and glass panels. I did not notice any difference between the two groups. Both groups had some pilots that had problems with basic attitude flying, and all of those showed great improvement after some instruction. But it's a small sample size, and I could easily be wrong. If you say that it's important to learn on steam gauges instead of glass, and you produce good pilots, I'm not going to argue with your methods.
It’s not important whether the display is electronic or mechanical, it’s important that it can be distilled down to the minimum relevant amount of information so the student can focus on that which is important to understand what the aircraft is doing in response to their control inputs, and how that correlates with the view outside.
If a glass panel display had a “minimum legal instrumentation for day vfr flight” mode then it would be a much better environment that a steam gauge six pack.
Once again, it’s not the fact of the electronic display, it’s the sophisticated integration of so much information that in my opinion makes it less than ideal for the first few hours.
The fact that this question is asked:
Is a warning sign that the OP thinks that learning to fly is all about gauges, or displays, and not about learning how to control an airplane. It’s the first danger sign of “instrumentitis”, the disease whose cure lies in covering the instruments during flight!What I have researched so far is that if i plan to work for the majors, learning in a glass cockpit will help me as the future planes I'd be in would be glass cockpit (vs steam guage).
