ARINC and FMS
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, Right Seat Captain
ProfessionalATC
ARINC and FMS
Post by ProfessionalATC »
Hello All , I have a few questions related to ARINC 424 and FMS and I seem to have difficulty finding them.
If anyone know any resources online that would help me I would appreciate it.
Are all the published instrument approach procedures possible to be coded as per ARINC 424 standard on a FMS Navigation Database?
Up to how many fields can contain an IAP record on ARINC standard?
Is an IF Path & Terminator the same on the Navigation Database than on a Navigation Chart?
What Path & Terminator will be used to code a 45, 180, 45 degree turn?
Can a missed approach point be a fly by way point ?
Thank You
tired of the ground
Re: ARINC and FMS
Post by tired of the ground »
Yes, if a procedure were unable to be coded it would be unable to be retrieved and therefore illegal to be flown by the fms.
I haven't heard of a limitation by standard. There are however storage issues within the FMS file servers that require truncated databases that often limit waypoints to required ones only. I.e. european approaches that may have 5 waypoints in a straight line on a downwind.
No, missed approaches are predicated on you starting the missed approach in a certain physical location.
Re: ARINC and FMS
The raw data for approaches in the US used to be in 14 CFR 97.11 but it was moved in 2016. Google for FAA form 8260-10 to pull up some examples of waypoint data that defines approach procedures, and the data therein might help.
example:https://www.faa.gov/aero_docs/acifp/201 ... A25A_F.PDF
