Really no 700question on IATRA?
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, Right Seat Captain
Mtlplt
Post by Mtlplt »
I read here that the IATRA isn't just for commercial pilots so the exam has no commercial questions. Studying the Harv's Air product, it has a dozen or so sections on commercial regs...
can i skip that part for now (for time issues)?
Scuderia
Re: Really no 700question on IATRA?
Post by Scuderia »
Part VII is indeed on the IATRA. See the study guide here: https://www.tc.gc.ca/eng/civilaviation/ ... w-2345.htm
PART VII – COMMERCIAL AIR SERVICES
700 - GENERAL
FLIGHT TIME AND FLIGHT DUTY TIME LIMITATIONS AND REST PERIODS
700.15 Flight Time Limitations
700.16 Flight Duty Time Limitations and Rest Periods
700.17 Unforeseen Operational Circumstances
700.18 Delayed Reporting time
700.19 Requirements for Time Free from Duty
700.20 Flight Crew Positioning
700.21 Flight Crew Members on Reserve
700.22 Long-range Flights
700.23 Controlled Rest on the Flight Deck
AIR TRANSPORT SERVICES
AIRCRAFT EQUIPMENT REQUIREMENTS
703.65, 704.64 and 705.70 Airborne Thunderstorm Detection and Weather Radar Equipment
703.67, 704.66 and 705.71 Protective Breathing Equipment
703.69, 704.68 and 705.75 Shoulder Harnesses
FLIGHT OPERATIONS
703.26, 704.22 and 705.30 Simulation of Emergency Situations
704.20 and 705.25 Fuel Requirements
704.26 and 705.34 Take-Off Minima
704.27 and 705.35 No Alternate Aerodrome-IFR Flight
COMMUTER and AIRLINE OPERATIONS
AIRCRAFT PERFORMANCE OPERATING LIMITATIONS
704.46 and 705.56 Take-off Weight Limitations
704.47 and 705.57 Net Take-off Flight Path
704.48 and 705.58 Enroute Limitations with One Engine Inoperative
705 – AIRLINE OPERATIONS
705.26 Extended Range Twin-engined Operations
705.29 Flight Crew Members at Controls
705.31 Crew Member Briefing
Mtlplt
Post by Mtlplt »
yes,
This post from two years ago put the idea in my head; it seems to be misleading.
Re: IATRA exam
Post by 455tt » Mon Jan 22, 2018 9:12 pm
These references are recommended to self study for the current IATRA exam:
https://www.tc.gc.ca/media/documents/ca ... 13524E.pdf
http://www.acceleratedaviation.com/webs ... rline.html
Tip: The IATRA exam is to qualify for a type rating on a 2 crew aeroplane, not to be captain of a 705 airline operated 2 crew aeroplane (that is what the ATPL is for). Therefore, you can disregard commercial operations related material (703, 704, 705 operations, for example). Your focus should be on high level, high speed operations in a complex, heavy 2 crew aeroplane which will include, for instance, principles of high speed flight such as Mach number, complex weight and balance, high level meteorology, principles of turbine engines, heavy aeroplane systems such as hydraulics, anti-skid, performance charts for take-off, cruise, landing etc. A wealthy PPL having purchased a 2 crew Lear or Citation without ever intending on flying commercially would write the same exam - yes it is weird but there are some lucky pilots in this situation.
Study hard and get a good score on your IATRA and you will find the ATPL SARON and SAMRA will be easier when you get around to writing them when you have the flight hours to sit them.
There are some good pointers and tips on this website in terms of what to expect on the IATRA but it is better for your overall knowledge to have completed the full TC recommended study in the first instance.
