Equipment by base
westisland
Equipment by base
Post by westisland »
Curious to know what equipment type is available to pilots at the each of the four bases (YVR, YYC, YYZ and YUL). Thanks in advance!
goleafsgo
Re: Equipment by base
Post by goleafsgo »
There's no yyc base but there's a ywg base
Here you go... it changes now and then, sometimes inexplicably...
YVR
L767/320/787/777
YWG
320
YYZ
EMJ/L319/L767/737/320/767/787/777
YUL
L319/L767/737/320/330/787
L767 is leaving YVR soon, likely to be replaced with 737
Flash8
Post by Flash8 »
Which silo of plane/base moves the quickest? (IE gets one off reserve quickest)
snag
Post by snag »
The rouge planes technically, as they do not have reserve, period.
Fastest movement at mainline would be at the junior positions in Toronto, ie. All RP spots and narrow body FO.
islandguy
Post by islandguy »
That's technically correct, but there's a significant caveat when it comes to narrowbody f/o in Toronto...when you get online, you might be showing at 20% right off the bat, but your flying and lifestyle will in no way resemble what 20% would get in a fully staffed roster.
i.e. your life is still going to suck. Pretty much have to avoid mainline narrowbody Toronto if you want to realize the benefits of seniority.
CZBBYYZPilot
Post by CZBBYYZPilot »
What's the flying like on the Airbus out of YVR? Will 737 impact it much?
CZBBYYZPilot
What's the flying in the Airbus like out of YVR? Will the 737 impact it?
bcflyer
Post by bcflyer »
The YVR 320 flying is pretty good. Better than out of YYZ in my opinion. Wide variety of destinations. Depending on your seniority it’s possible to get down to 8-12 days a month. As for what impact the 737 will have, it’s planned to do all the Hawaii flying, so initially I would think it won’t make much difference. Long term is anybody’s guess.
ToolShed
Post by ToolShed »
islandguy wrote: Tue Jun 12, 2018 1:36 pm That's technically correct, but there's a significant caveat when it comes to narrowbody f/o in Toronto...when you get online, you might be showing at 20% right off the bat, but your flying and lifestyle will in no way resemble what 20% would get in a fully staffed roster.
This is not correct.
You will accrue seniority QUICKER as a mainline narrowbody FO because pretty much all new hires are being trained as NB FOs!
Bravomike33
Post by Bravomike33 »
Hello !
Thanks, that a nice post.
Some chance to see a A350 in a futur AC fleet ?
islandguy
Post by islandguy »
ToolShed wrote: Sat Jul 07, 2018 3:35 pm
No.
You'll accrue seniority at exactly the same rate, but it will be worth less because the positions are so short staffed. I have friends who were hired on as Toronto 320 FOs and immediately showed under 20% as a percentage of required positions, but were still bidding at the 90th percentile of the guys who were actually on the base. All of these guys have now bid OFF the 320 in Toronto because the lifestyle, to put it simply, sucked.
Post by 8895 »
Curious to know what the equipment/base numbers are looking like at this point. Heard a lot of new hires going onto the 220’s. What base/equipment seat gives you the best chance at having your desired schedule at this point?
bring me the horizon
Post by bring me the horizon »
bob99
Post by bob99 »
8895 wrote: Wed Feb 08, 2023 2:16 pm Curious to know what the equipment/base numbers are looking like at this point. Heard a lot of new hires going onto the 220’s. What base/equipment seat gives you the best chance at having your desired schedule at this point?
The new hire positions can be quite different class to class. Late Jan there were only 3 220 spots, but 26 wb spots (not including the freighter). There's vacancies on everything and it usually comes down to training capacity (sim/instructor availability etc). Everyone's definition of "desired schedule" will be different. How quickly you move up the list won't differ too much between the nb types, and there's frequently so many changes to commercial planning that trying to be strategic about what might happen in the future could backfire.
Post by 8895 »
bob99 wrote: Sun Feb 12, 2023 11:13 am
Thanks for the reply. Fair to say anyone getting on over the next year or so would be able to move up the list faster on the NB side of things as opposed to WB? Seems to be more new NB metal coming in compared to WB, even if a decent amount is just to replace aging 320’s.
Any guess on how long all these new WB FO’s would be stuck on reserve? I imagine there isn’t too much growth with the WB ops to change things that much.
skyhighh
Post by skyhighh »
WB FOs would be on reserve for a while. Often people do their time on other aircraft and then when they have enough seniority and can make enough cash being a WB FO they move onto these positions.
Getting a WB in PIT is nice if you want to fly big planes and get international experience but unfortunately you’ll have someone more senior jumping above you for quite some time keeping you on reserve. It’s one of the reasons why RPs were so popular, almost nobody would be parachuted above you as most people taking RP positions were from PIT and therefor behind you.
I hope that helps.
Blueontop
Post by Blueontop »
What is the QOL like for the RPs on the WB vs. being an FO. If one was trying to decide between one or the other what would be the cons and pros of each? TIA
Crewbunk
Post by Crewbunk »
A WB R/P could get senior quicker. (It depends on the base). You’ll have an easier schedule with long legs and high expenses. You’ll see some cool destinations.
But you’re a pilot. You want to fly. An A220 F/O will get lots of flying. Flying a new, pretty advanced aircraft. Flying with young, eager Captains. (Not crusty old gits like me).
One new hire R/P I flew with recently (I fly the 330) said it best. He said it’s very easy to get very lazy very quickly, it’s such an easy job.
I’m not sure when you get access to Aeronet. If it’s before your first equipment bid, check out the blocks. That may help you decide.
Blueontop
Post by Blueontop »
Crewbunk wrote: Fri Apr 28, 2023 8:20 am A WB R/P could get senior quicker. (It depends on the base). You’ll have an easier schedule with long legs and high expenses. You’ll see some cool destinations.
Can you define easy a bit more, besides the not physically flying part? Getting senior relatively quickly means getting off reserve quicker? And being on reserve how often are you getting last min/day off/day before flights? Once off reserve how many days a block flying/how many days away in a row is one gonna expect? Does an RP make less than an FO once off flat pay or is there no RPs off flat pay? High expenses due to international destinations I assume you mean but you going to make more in per diems I guess? I think I would prefer an RP position over FO due to never ending slog I’d be coming from but want to make sure I know all the angles first.
Return to “Air Canada”
