Rouge is back?
Re: Rouge is back?
Yes, but it's a flat bid. They are reducing the mainline bus while adding the Rouge spots. There is no increase in available seats, so everyone identified as surplus/furlough stay there.
Re: Rouge is back?
Also worth mentioning:
Surplus pilots at rouge (Airbus only) will be "made whole" and re-trained to current qpos just as their mainline counter parts have been doing.
After they are trained they will be awarded flying till their layoff (should that ever come).
- Daniel Cooper
Re: Rouge is back?
Can surplus pilots participate in equipment bids or are they stuck in their position until they are no longer deemed surplus? I assume that is when the first furloughed pilot is recalled. Or can they be deemed non-surplus before then?
Re: Rouge is back?
Surplus pilots do not have bidding rights. The remain in their Qpos. Even if that position is no longer around.Daniel Cooper wrote: ↑Fri Oct 02, 2020 12:46 pm Can surplus pilots participate in equipment bids or are they stuck in their position until they are no longer deemed surplus? I assume that is when the first furloughed pilot is recalled. Or can they be deemed non-surplus before then?
Re: Rouge is back?
No furloughed pilots need to be recalled before a surplus pilot is returned to active status. If the company decides that they need another 100 active pilots, they can put out a CMSC review reflecting that, and you will see the next 100 most senior pilots removed from the surplus list.Daniel Cooper wrote: ↑Fri Oct 02, 2020 12:46 pm Can surplus pilots participate in equipment bids or are they stuck in their position until they are no longer deemed surplus? I assume that is when the first furloughed pilot is recalled. Or can they be deemed non-surplus before then?
