Hi-Fly A340 Fuel Jettison During Landing MCO
complexintentions
Post by complexintentions »
I'd be interested to get Eric's thoughts on this one, particularly as its being identified as a Norwegian plane. It is a Norwegian leased flight, but not a Norwegian aircraft or crew...kind of an important distinction.
Orlando airport doused in jet fuel when Norwegian plane made emergency landing
By Kevin Spear
| Orlando Sentinel |
Jul 03, 2019 | 3:34 PM
A Norwegian Air plane that aborted an international flight spewed a substantial amount of fuel on a large area of Orlando International Airport during its emergency landing, which an aviation expert described as a rare and potentially dangerous occurrence.
The incident happened late Saturday night, triggered initially by warnings of a failed hydraulic pump. Federal authorities have since begun an investigation while airport officials are assessing costs for cleaning up runway and taxiway surfaces.
The Norwegian flight, using a 19-year-old leased aircraft, was well out across the Atlantic Ocean when it reversed course and returned to Florida. Passengers were on board for nearly five hours, or more than half the time they would otherwise have spent on a flight to London’s Gatwick airport.
The returning flight was met by emergency vehicles, and passengers were held on the plane for an hour. Portions of the airport tarmac were closed temporarily so that crews could remove the spilled fuel.
Judy Watson Tracy was on that flight and from a window on the plane’s right side photographed a fountain of jet fuel coming from the rear edge of the wing to the runway.
Charles Westbrooks, aeronautical science professor at Embry-Riddle Aeronautical University and a former airline pilot, said most pilots never experience having to dump fuel. Far more rare is spilling fuel at an airport, he said.
“It would not be done intentionally,” Westbrooks said. “I can think of no reason why anyone would do that on purpose.”
Neither Norwegian nor the company providing the leased Airbus 340 for the London flight, Hi-Fly of Portugal, would explain why the wide-body aircraft dumped fuel on the airport’s runways and taxiways.
“As a standard safety practice, fuel was dumped prior to the safe landing of the aircraft at MCO, however there may have been some residual leakage from its wings,” Norwegian spokeswoman Min Kim said.
A HiFly spokeswoman said there was “no emergency situation” from a hydraulic pump’s “malfunction indication.”
“The aircraft was on the initial phase for a long haul flight to Europe so fuel had to be dumped to bring the aircraft into adequate landing weight,” Inês Pompeu dos Santos said.
The Federal Aviation Administration, confirming that it is investigating the aborted flight, said in a statement the “Norwegian Air 7058, Airbus A343, landed safely at Orlando International Airport at 9:53 p.m., June 29, after the pilot reported a loss of the aircraft’s primary hydraulic system.”
Westbrooks said a plane such as the HiFly Airbus would dump as much as 30,000 gallons of jet fuel in order to shed weight for a safe landing.
Pilots try to dump fuel over water if possible or over a rural area. With the plane traveling at several hundred miles per hour, dumped fuel quickly atomizes into a fine mist or vapor.
Dumping it on a runway is another matter, Westbrooks said, especially if it accumulates beneath the plane.
“You potentially have 200 or 250 people sitting on top of a flammable substance and the engines are running,” Westbrooks said. “I would not be comfortable with that at all.”
Orlando airport authorities said the amounts of fuel dumped on runways and taxiways of the airport’s west side “are still being determined but was of significant size.”
They said airport leaders are unaware of such an incident occurring previously.
Contractors were called in for a cleanup and costs have not yet been determined, airport officials said.
The website FlightAware shows the airplane reached an altitude of 35,000 feet and was east of North Carolina’s coast when it turned back to Orlando.
As the Airbus neared Florida’s coast at Daytona Beach, it completed four, large circles while still over water, and then flew to Orlando International Airport.
Not clear is whether the aircraft was dumping fuel over the Orlando metro area as it approached the airport.
Norwegian began to alert passengers earlier this year that it was relying on leased aircraft that are older than the airline’s newer Boeing 787 airplanes, which reportedly are in need of engine maintenance.
“We are contacting you to inform you that your flight will be operated by another Carrier,” Norwegian Air said in a statement. "We understand that these changes are not ideal, but it was necessary for us to lease an aircraft from another Carrier in order to avoid a disruption to your flight
Eric Janson
Re: Hi-Fly A340 Fuel Jettison During Landing MCO
Post by Eric Janson »
complexintentions wrote: Fri Jul 05, 2019 2:10 am I'd be interested to get Eric's thoughts on this one, particularly as its being identified as a Norwegian plane. It is a Norwegian leased flight, but not a Norwegian aircraft or crew...kind of an important distinction.
It was indeed one of my Airlines aircraft operated by a crew from my Airline and wet leased to Norwegian.
I'm assigned to a different client and I don't do these flights.
For the rest I know what has been published - have heard nothing from the company.
The photo does show fuel being dumped from the pipe that is there for that purpose.
Fuel dumping requires two guarded switches to be pressed - "ARM" and "ACTIVE" before dumping will commence. It is also possible to enter a weight in the FMGC at which fuel dumping will stop. Fuel dumping can also be stopped at any time by turning off the guarded switches.
Fuel is dumped at a rate of 1000kg/minute.
ZBBYLW
Post by ZBBYLW »
Hey Eric, does it use vacuum/pressure to suck or push out the fuel or is there an actual pump to pump out the fuel? Based on the fact its still pissing away on landing I guess it may be a pump.
boeingboy
Post by boeingboy »
They are pumps - and boy are they powerful!
I was working in the hanger years ago and saw a 767 in the maintenance dock when one of the mechs accidently turned them on - the fuel shot back with enough force that it hit the hanger doors. it was quite the sight. The hanger was evacuated pretty quick.
Eric Janson
ZBBYLW wrote: Mon Jul 08, 2019 8:22 am Hey Eric, does it use vacuum/pressure to suck or push out the fuel or is there an actual pump to pump out the fuel? Based on the fact its still pissing away on landing I guess it may be a pump.
Uses the fuel pumps (4 normal pumps + the 4 standby pumps which are automatically turned on).
FL410AV8R
Post by FL410AV8R »
Is it a possibility that it was just residual fuel in the lines out to the nozzles that remained after the pumps and valves were shut off, and this just leaked out after landing. I know on the B767-300 the fuel jettisons out of the centre tank through 2 nozzles at a rate of 2600lbs/min so there is a lot of fuel in those lines.
Any further news on how this happened. As it has happened at least twice this year, it would be interesting to know how the crews got into the situation.
Eric Janson
Nothing official.
I did receive some technical information on the fuel dumping system.
If a weight is entered on the FUEL PRED page fuel will be dumped down to this weight then fuel dumping will stop no matter what position the 2 fuel dumping switches are in.
After landing the FMGC goes to a "Completed" mode after 30 seconds and erases various data including any entries on the FUEL PRED page.
At this point if the fuel dumping switches are still in the "ARM & ON" position fuel will once again be dumped.
The official report will clarify what happened.
Checklist procedure should cover that.
