I can get behind this statement.Right Seat Captain wrote:All this being said, I have to say I really enjoy flying at night, including on X-countries, assuming they are properly planned. It may be risky, but so is skydiving, and many other activities that we do. Aviation is always about managing the risk, and this is no exception.
I believe that night experience on the CPL license is similar to the instrument flight time. It is there to give you the experience should you get yourself into a bad situation-- how to get out (in this case, fly to the nearest airport and land). Quite applicable to single engine VFR operations (because people can and will mess up).
So- would it be fair to say that the dual cross-country requirement is good experience, and that the benefits outweigh the risks, provided the route flown is over an area where there are suitable airports close by (and definitly not in mountainous areas or over open water)?
I have always beleived that the night experience was a great time to teach the proper use of radio nav aids (during the dual cross-country portion) due to the fact it was easy for an inexperienced pilot to get quite lost.
Summary:
-Solo circuits only
-Dual circuits with some dual cross-country requirement for familiarization
(from reading between the lines of what has been said here)
Darn near the requirements for the night rating (and night portion of the CPL) now. Any CFI or flight instructor could/should place limitations on their students in order to limit any additional risk. I don't believe anyone here wants more limiting legislation when common sense would do a better job.
In my region, the last two accident at night were due to students ducking under on short final and colliding with objects on the ground PRIOR to the runway (so Nav Canada installed PAPI's at both locations to reduce the risk of this happening again).
Side note: IF THE RUNWAY YOU ARE LANDING ON AT NIGHT IS EQUIPPED WITH A PAPI SYSTEM, BE SURE YOUR STUDENTS USE IT!
(That is real world stuff there! Teach it!)
Agree? Disagree?
-Guy
