A, I think some of us (GA pilots) aren't willfully ignoring the standard to be "cool". Personally, I think its a genuine effort to fit into the normal language TML here uses every day, and their clear expectations in a response, and it's clear what they want to hear, in certain situations from VFR's. IE, along the lakeshore, where it is very busy and opposing traffic will be 500 below, they prefer to hear the altitude repeated. I know this -- it's not standard or required, but why omit it (information) unless the radio is nuts? They will call again -- for sure. It's almost never too nuts. New York approach is nuts, by comparison.ahramin wrote: ↑Mon Mar 05, 2018 9:42 pm I'll say this again: please don't use poor controllers as an excuse. Controllers are almost as guilty as pilots when it comes to non standard phraseology, and NavCanada is cracking down with good reason. Also if you are planning on flying anywhere else in the world on a regular basis, please take the NavCanada VFR Phraseology document with a grain of salt, it has a few examples of specifically ignoring ICAO standard phraseology to no purpose.
Fly enough around here, it's not hard to tell what the normal flow sounds like. Maybe that's the wrong approach, I admit. ie, I don't think I use "check remarks", but every terminal controller uses it.
If you are flying out west, ask for lower, and they aren't ready to say yes -- very common in the US too -- how do they answer you? "I have your request" is another way, that's even longer. "Stand by" ? That can be ambiguous too.
