Logging Co-pilot time, VFR only ops
Maybe someone on here can direct me in the right direction. What is 'qualified' mean to be able to fly co-pilot on an aircraft under 12,500lbs in a commercial environment. Is a checkout required? Operation is VFR day only.
- HiFlyChick
Re: Logging Co-pilot time, VFR only ops
The AOC specifies the number of crew members, which must then be reflected in the COM. The operation must also have SOPs to operate 2 crew. The qualifications of the crew (like the F/O having a PCC or PPC and the PIC having a PPC) are outlined in CAR 703.88.
- TheRealMcCoy
And make sure you get a letter/print out in the COM stating they operate the plane two crew, when you send in your paper work for your A's
Great comments, thanks for your replies.
