Whats your Shortest non stop flight?
What is your personal shortest flight, sorry float guys from two aerodromes...
Mine CAH3 - CYQQ, 4nm according to great circle mapper for a 172.
CYVR-CZBB 10nm in a KingAir
CYVR-CYYJ 33nm in a DHC-8
200hr Wonder
200hr Wonder
Re: Whats your Shortest non stop flight?
Doug Ronan's to Skywagon City, 1/3 mile (Google earth) liftoff touchdown.
4nm from Oliver BC to Covert Farm beneath McIntrye bluff in a Taylorcraft.
KSTP to KSGS, 4.5 nm and KGSP to KGMU, 6.8 nm. Both in a jet, they make for quick flights.
Fort Albany (YFA) to Kashechewan (ZKE), in Ontario. 90 seconds at 500' in a PC-12
CYNJ-CYPK, 8nm. Zero cruise time, as soon as I'm clear of Langley's zone I'm starting my approach in to Pitt Meadows.
KBLI-CYXX, 16 nm. Shortest international flight.
...laura
...laura
Not sure the distance, but it was 4 minutes, reached 235kias at 500agl. Was a straight in final, didn't start slowing down till 4 miles out. Flight idle, drop gear and flaps, on profile and stable by 1.5 miles, still at 500'.
9 minutes GCRR - GCFV
9 minutes EHRD - EHAM
Both with the 737-300.
I have done the same trip several times, but it took me a bit longer.EHRD - EHAM
However when I was based at EHVB it was even closer to Rotterdam.
Big Trout Lake to Angling Lake. 11.4NM
And YVR - YCD in the Q400, fastest I've ever done it was 8 min air time.
Downsview to Pearson in a Dash 8......... 2minutes and 58 seconds airtime on to runway 23.
Let’s Go Brandon
CKQ9-CZTA 11nm PA-31,C-208 padded the logbook with all those .1 sched flights.
comox to campbell river in a DHC-100. Why even raise the gear...
- youhavecontrol
CCN3 to Linden Airstrip. About 10nm in a 182RG... barely had the landing gear up for more than 2 minutes. The start checks and engine run-up took about twice as long as the flight!
King City to Maple < 4 nm. Lots of folks did it, especially if no gas at one or the other. But KC is now a construction equipment parking lot while Maple is a housing development. Buttonville and Downsview to follow?
For sure, remember Barker Field?King City to Maple < 4 nm. Lots of folks did it,
From the end of the runway to where I landed: about 1100 meters
From the end of the runway to where the airplane landed: about 2500 meters
I suppose you have to be in the airplane to win the contest...?
(;>0)
(;>0)
was with someone that did CZBB-CAK3 (3 NM).
