Canada To Decommission Hundreds of VORs, NDBs
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, I WAS Birddog
golden hawk
Post by golden hawk »
https://www.ainonline.com/aviation-news ... -vors-ndbs
by Gordon Gilbert
- March 4, 2019, 12:08 PM
Nav Canada, the country’s provider of civil air navigation services, has finished a study of navigation aids and concluded that “given the comprehensive radar surveillance coverage, and the propensity of area navigation (Rnav) with global navigation satellite system (GNSS) equipped aircraft, many VOR and NDB navigation aids (navaids) are no longer required and should be decommissioned.”
The decommissioning process will be done in 15 phases over the next seven years. Where a current navaid identified in the study serves as an instrument approach aid or anchors an airway segment, Nav Canada said it will “ensure that a Rnav/GNSS instrument approach procedures or Rnav airway segments are published, where required, before removal of the identified navaid.”
Aeronautical information circulars (AICs) will be published for each upcoming phase, Nav Canada said. The first phase, consisting of decommissioning some 20 navaids deemed nonessential, will start on April 25. Corresponding aeronautical charts will also be amended.
Nav Canada’s action follows the FAA’s decommissioning of legacy navaids that started in 2012. Under the U.S. agency’s planned schedule, a minimum operational network of VORs and an “optimized network” of DMEs would be retained, and this drawdown would be complete by January 1 next year.
linecrew
Re: Canada To Decommission Hundreds of VORs, NDBs
Post by linecrew »
Phase 1 AIC is already out.
Link to the AIC
Mostly Harmless
Post by Mostly Harmless »
It's a good thing GPS jamming and GPS spoofing are not real things happening around the world.
It’s just the VORs and NDBs that are disappearing. The co-located DMEs and TACANs are remaining in service.
YWL VOR has been NOTAMed off for a long time but the DME still works and identifies.. allowing you to use DME DME RNAV or RNP on a multi-sensor FMS without GNSS.
In the US at least, there appears to be a long term trend towards supporting DME DME Navigational infrastructure with improved accuracy.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6210753/
goingnowherefast
Post by goingnowherefast »
Mostly Harmless wrote:
Mon Mar 04, 2019 3:27 pm
Or solar storms. Granted big ones are rare, but in the future they will now ground the entire IFR world due to no navigation.
dhc#
Post by dhc# »
Time to dust off the ole' Astro Compass
C-GGGQ
Post by C-GGGQ »
goingnowherefast wrote:
Mon Mar 04, 2019 6:11 pm
Cause radio waves were impossible to jam? :roll:
linecrew
Post by linecrew »
Apparently there will be a recovery network of conventional NAVAIDs left in place in case of a GPS outage.
There's a bunch of info from Nav Canada here.
tsgas
Post by tsgas »
linecrew wrote:
Mon Mar 04, 2019 6:56 pm
IFR in Canadastan will mean "I Follow Roads". :lol:
Meatservo
Post by Meatservo »
I hope they leave some NDBs in the NDA. Even with RNAV approaches and GPS, it's nice to have some way to set your compass "independent of a magnetic source". Unless you can see the sun and happen to have your astrocompass and a current almanac, or you happen to be able to see Polaris, NDB/GPS is about the way to go for this. The magnetic pole was heading steadily towards the geographic one, but now it's kind of gone bugshit. Who knows what it's going to do next.
lownslow
Post by lownslow »
We're also losing the ability to circle to land from most approaches.
B208
Post by B208 »
C-GGGQ wrote:
Mon Mar 04, 2019 6:52 pm
True. However, you can't buy ILS/NDB/VOR jammers on Amazon.
goingnowherefast
And a solar storm knocks out GPS for a very large area over a long time frame. Definitely able to take out RNAV capabilities at the destination and anything else within fuel range. Radio jammers, not so much.
Granted they're rare, every 30-50 years? But that's pretty drastic consequences.
Hopefully the "recovery network" is kept in top notch condition, and aren't dependant on circling NDB approaches that aren't even turned on until they flip the switch for the "recovery network". I can just imagine everybody flying nothing but LPVs and ILSs for 10-20 years, solar storm hits and now we're fumbling our way around with NDBs that nobody even had the ability to use and stay proficient with.
Also, the last time the US detonated a nuke in space, it did serious damage to the few satellites that were up there at the time. Should N. Korea or somebody else get that idea, they'd decimate the navigational abilities of a GPS dependant airspace system.
77W
Post by 77W »
lownslow wrote:
Tue Mar 05, 2019 6:19 am
Do you have a reference? Legitimately interested in reading up on this.
Not on any approaches I’ve noticed. There usually isn’t a reason to circle anymore because you have LPV approaches at the opposite end of any single ILS installation, but the provisions are almost always there with the exception of busy airports.
In the US, they even have the higher circling minimums which allow for a wider circling area... making circling able to turn into more of a reasonable circuit rather than having people excessively close and high trying to maneuver the aircraft to landing.
https://www.ainonline.com/aviation-news ... ce-expands
Hugh Jasshole
Post by Hugh Jasshole »
About a month ago, none of the blue and teal 37's had GPS in the morning at YEG. Many MEL's were applied to headstarts. I assume our neighbors had similar GPS issues?? They thought maybe a truck in Nisku had a jammer?
lownslow
Post by lownslow »
77W wrote:
Tue Mar 05, 2019 8:30 am
http://www.navcanada.ca/EN/products-and ... oke-EN.pdf
I often circle for efficiency, if these procedures really were deemed that dangerous I would have preferred to see the minima get pushed up or the assessed area be expanded.
lownslow
Post by lownslow »
iflyforpie wrote:
Tue Mar 05, 2019 9:29 am
I like circling because it allows me to fly the most direct approach then maneuver below cloud to land on a more into wind runway. The alternative often has me overflying my destination by 10-15 miles then turning around and doing a straight-in approach. In flat-ish land with a MSA of 4000 and a ceiling of 3500 there's plenty of room to be safe while saving hundreds of dollars worth of gas in a light twin when I do it that way.
goingnowherefast
That sounds to me like it is more of using an instrument procedure to cloud break, then maneuvering under VFR to a landing.
lownslow
Post by lownslow »
Tue Mar 05, 2019 2:54 pm
It is, but it’s a hell of a lot easier to communicate to ATC my way.
Yes I often use circling this way as well. And you do have to notify the applicable ATC that you are intending to circle. I know someone who got CADORSed that didn’t..
That really sucks if they are going to take that away from us.
In some mountainous places it’s almost 60 miles between initial fixes to opposite ends of the runway because of terrain.
Tail hook
Post by Tail hook »
Hopefully they will reduce my Navcan fees to off set the price of maintaining my GPS database.
Zaibatsu
Post by Zaibatsu »
I CANT BELIEVE THEY ARE DISCONNECTING NDBS WHY BACK IN MY DAY WE COULD GO ZERO ZERO IN A BLIZZARD 50 KNOT CROSSWIND ON A THOUSAND FOOT DIRT STRIP WITH A FIXED CARD ADF A COMPASS A WRISTWATCH AND A BOTTLE OF RYE AND WE WERE FAR SAFER THAN THIS MAGENTA LINE GENERATION
lownslow
Post by lownslow »
Zaibatsu wrote:
Wed Mar 06, 2019 9:54 am
Yes, I do feel that way. Thank you for noticing.
linecrew
Post by linecrew »
tsgas wrote:
Mon Mar 04, 2019 9:34 pm
*"I Follow RNAV" :wink:
