VFR and CFIT
C.W.E.
VFR and CFIT
Post by C.W.E. »
Why do so many pilots push the weather and crash?
Hilroy
Re: VFR and CFIT
Post by Hilroy »
Poor planning and inadvertant IMC... Lost of situation awareness.
Master of Cessna 172
It has been 0 days since I've almost died in an airplane.
Never trust a student with fuel and oil.
Re: VFR and CFIT
Failure to maintain enough situational awareness to prevent hitting earth or an obstacle. The weather is not the problem, it's failing to keep the plane in the correct place in space, pointed the right way!
Worse, it's the temptation to allow automation to take you somewhere you should not go, because you trust the automation too much! Yeah, we're suppose to "trust our instruments", but there are times to ask yourself how sure you really are.
I did not have a CFIO (obstacle) a few summers back, flying my friend's 182 amphib (the same plane I visited C.W.E. in years earlier) down the coast of Finland. It was poor weather, VMC, but poor, and worsening. I decided to turn back, and head for my alternate. Surprise, since I'd passed it a half hour earlier, it had closed! Going 200 miles back to the origin was unattractive. So, while already in radio communication with a large airport not too far ahead (Oulu), I asked if they could accept a request for special VFR. The response was a very welcoming "Of course!". Okay, I guess I'll do that.
So this plane is full glass cockpit (G500), and full steam gauge, with a Garmin GTN750, ADF, and a King Nav/Comm with ILS, just in case. All databases right up to date, and a full set of paper Jeppeson's just in case - so, it's not like we're poorly equipped for marginal weather flying! I enter "Oulu" and shazam! a Magenta line! Now, I'm over the Baltic Sea, at 700 feet or so, and this very tempting magenta line would like me to fly direct to the really welcoming, big, well lit runway - I could follow that - trust the automation! No warning flags, I have a clearance direct, weather is deteriorating, and it's been a long day of flying. But, my little voice says "no". 'Cause my little voice knows that I've been seeing wind turbines all along the coast! Now, there are no obstacle warnings ahead on the G500 with synthetic vision, but my little voice.... So I stay out over the water. To keep the task saturation low, I ask the owner, who's right seat, to dig out the Jeppeson for runway 12 at Oulu - he finds it. I dial in the localizer to 12, and continue south over the water - 'cause I know that there are wind turbines on shore, but they don't put wind turbines in large airport departure paths. I intercept the localizer, follow it in, intercept the glideslope, and voila, nicely lit runway.
'Next day, beauty weather so off we go on 30. Owner is flying, and I'm admiring the wind turbines on both side of the departure path, which I did not fly through the day before. 'Little voice was goo, but obviously the automation let me down badly, as it painted a magenta line, and presented zero obstacle warnings. Ah, now, I am seeing wind turbines as obstacles left and right! What's different! Read the Garmin manual. It turns out that the factory default is such that when you select a 25 mile or greater screen display, all the obstacles are decluttered - and there is no flag telling you that. If terrain is disabled, you get a flag, but not obstacles! So I went in, and changed that to 50 miles, just to be sure! Still no warning flag, but 50 miles gives you lots of time to think about what you're doing!
So it was fun flying with all the tech for a few dozen hours, but I learned to trust my tried and true experience, and little voice, and then consider the information from the tech. Then, I was right seat for an accident - in perfect weather!
TeePeeCreeper
Re: VFR and CFIT
Post by TeePeeCreeper »
PilotDAR wrote: Tue Apr 16, 2019 8:09 pm Failure to maintain enough situational awareness to prevent hitting earth or an obstacle. The weather is not the problem, it's failing to keep the plane in the correct place in space, pointed the right way!
Sounds like you boxed yourself in and are or were confusing the lines... I don’t care if you were IFR equipped.... it’s a moot point.
With all due respect, one is either VFR or on an IFR plan.
Pretty cut and dry to me really!
Re: VFR and CFIT
Yes, I certainly boxed myself in, not realizing that my alternate airport would close minutes after I passed it, headed another 25 miles to my destination. Special VFR is still VFR, and I suppose better than landing at an airport I've just been told I may not land at. I was quite comfortable flying in the special VFR conditions, other than for wind turbines which I knew were there, but had too little information about, and preferring to not demonstrate less than ideal VFR practice to my fellow pilot (whom I was training that trip). So, yes, I boxed myself in....
goingnowherefast
Re: VFR and CFIT
Post by goingnowherefast »
It's a great story, thanks for sharing. There are dangers of combining IFR and VFR procedures. Using navigation equipment designed for IFR, but not maintaining IFR safe altitudes in bad weather is one of them. The magic box will take you anywhere you want to go, but leaves obstacle clearance up to you. You're local knowledge and experience saved you because, flying under special VFR, obstacle clearance is your responsibility.
Re: VFR and CFIT
Yeah, it was the obstacle clearance part which I took seriously. With all of the database up to date, and knowing that obstacle awareness was a feature of the system, my failure to know that the zoom scale would turn off obstacles, and there would not be a warning flag was the puzzling thing to me. I agree that it's IFR type equipment in a VFR (or special VFR) environment, and that mixture could be deceivingly dangerous. I will hope that in future versions of similar systems, perhaps the magenta line could flash or something, to tell you that yes, you can fly from A to B, but at your present altitude, you don't have the clearance over obstacles. The terrain awareness sort of does this by surrounding you with red until you climb, I take obstacles as seriously as terrain, I wish that Garmin displayed them with similar discipline!
My acute awareness was because I had no local knowledge, my first and only time in that area. But, that made me hyper aware. For the flying I do in northern Germany, I have learned to expect wind turbines everywhere! (except runway departure paths!).
The magenta line is so tempting to follow, it takes willpower to resist the force sometimes, and then it's on you to have a yet better plan!
TeePeeCreeper
Re: VFR and CFIT
DAR,
Pop quiz? (pun intended!) can one pick up an IFR clearance in Finland once airborne a la “pop up clearance” that our neighbours to the South have?
All the best,
TPC
Re: VFR and CFIT
I truly don't know. We were only there for the overnight, passing through from the far north of Norway. As conditions were within special VFR, I was very close to the destination, and the tower was very welcoming, I kept things simple, flew at 700 feet over the sea until I intercepted the localizer, and then turned in. As I was in sight of the ground the whole time, and with adequate forward visibility for special VFR, I did not want the distraction of changing the flight plan. It had been a long day of flying, I was tired, and I did not want to prolong nor complicate things for myself. The owner was right seat, and though a very proficient pilot, he was newly licensed and not able to support me much in IFR type flying, so keeping the whole thing within my comfort level was increasing in importance.
Those weather conditions would have been "comfortable" for me flying around home. It was the combination of knowing there were wind turbines on shore, no obstacle display when I knew there were obstacles, and then a magenta line painted right across where I really believe that there could be wind turbines which alarmed me.
Interestingly, once I reset the default to the maximum of a 50 mile screen zoom, the display was cluttered with obstacles, but that's what the display is for. Later the next day we were southbound over eastern Sweden in very nice weather. At 3500 feet, I was seeing a red obstacle conflict identification ahead. As I neared with great caution, the obstacle was marked as being in a Swedish wind turbine farm. I could not imagine a wind turbine, or other tower being 3000 or so feet above ground! We gave it a mile pass anyway, but I did visually confirm that it was just one of the wind turbines with an error in the obstacle database as to its height - Then, the system worked!
YYZSaabGuy
Re: VFR and CFIT
Post by YYZSaabGuy »
TeePeeCreeper wrote: Tue Apr 16, 2019 9:18 pm Sounds like you boxed yourself in and are or were confusing the lines... I don’t care if you were IFR equipped.... it’s a moot point.
He was flying VFR in VMC conditions, the weather changed, his alternate closed, he requested and was approved for SVFR, picked a new alternate that was close by, and used a the on-board tools (glass cockpit, steam gauges, and Jeppesons (and CRM!)) to come up with and then implement a workable solution while maintaining enough situational awareness to think about and avoid unflagged obstacles. Sounds like pretty heads-up flying to me!
Daniel Cooper
Re: VFR and CFIT
Post by Daniel Cooper »
These answers are saying why the plane crashes but if we go back further on why the pilot puts themselves in that situation in the first place it's usually a desire to get the job done. That pressure coming from themselves, and their company culture, usually in that order. It's the nature of the type of people that do these jobs. Companies should be actively reigning people in, not allowing them to push on, and especially not encouraging them to.
C.W.E.
Re: VFR and CFIT
Post by C.W.E. »
And therein lies the real problem.
These people should be fired.
goingnowherefast
Re: VFR and CFIT
Daniel Cooper wrote: Thu Apr 18, 2019 8:17 amCompanies should be actively reigning people in, not allowing them to push on, and especially not encouraging them to.
CWE, you forgot the important part of Daniel Cooper's post.
How do you expect a manager to fire somebody when that same manager actively encourages pushing the weather? Hundreds of pilots every day tell their management to go pound sand. Usually nicely, sometimes, not so nicely. If an accountable executive was actually held accountable, we'd see the change happen tomorrow by lunch time. If an accountable executive was given a million dollar file and/or jail time after a crash, the safety culture at every company in Canada would change in record speed.
C.W.E.
Re: VFR and CFIT
Post by C.W.E. »
The manager is not the pilot who holds the license and is responsible for every flight that said pilot accepts.
Therefore every pilot who knowingly violates the regulations should be fired.
Being fired for just cause will be detrimental to a pilots ability to get a job, being fired more than once for the same reason will really affect a pilots career.
By the way who is responsible for enforcing the regulations?
Who has the power to suspend or cancel a pilots license?
Are we getting close to how to solve the problem?
And by the way when I owned my aviation companies I had all new hire pilots sign an employment agreement that clearly stated that any deliberate noncompliance to the regulations would result in immediate dismissal.
I never had a problem with pilots breaking the law.
Re: VFR and CFIT
TeePeeCreeper wrote: Thu Apr 18, 2019 2:51 am DAR,
All the best,
TPC
If it's like the rest of European airspace, no. If you're VFR you're not in controlled airspace, and if you're not in controlled airspace then no control service is available. There's almost no Class E airspace, which is controlled but open to VFR flight.
However, since you're not in controlled airspace you don't need a clearance for IFR flight. Just carry on. But - you can't enter controlled airspace later in the flight.
Pronouns: he/him
trey kule
Re: VFR and CFIT
Post by trey kule »
As we are off topic, pilots blaming management for pressuring them is a cop out.plain and simple. No civilian job is worth killing yourself for
The challenge is weather changes. Pilots overestimate their abilities, and generally the transition is not instantaneous. It just keeps deteriorating, and the pilot kerps going until all the doors are closed. The ground is close and pilots try to fly VFR in IMC.
Accident speculation:
TeePeeCreeper
Re: VFR and CFIT
photofly wrote: Thu Apr 18, 2019 4:38 pm
All the best,
TPC
Thank you Photofly, appreciate your answering my query.
shimmydampner
Re: VFR and CFIT
Post by shimmydampner »
C.W.E. wrote: Thu Apr 18, 2019 4:26 pm The manager is not the pilot who holds the license and is responsible for every flight that said pilot accepts.
trey kule wrote: Thu Apr 18, 2019 4:43 pm As we are off topic, pilots blaming management for pressuring them is a cop out.plain and simple. No civilian job is worth killing yourself for
Well, it's all very simple sitting retired behind a keyboard, but the reality is less so. And I suspect if you're both as experienced as you claim to be in old school bush operations you understand that, as black and white as these things may seem in an ideal world, that's not the world we inhabit.
trey kule
Re: VFR and CFIT
Post by trey kule »
Well Shimmy,
I agree itis not black and white. There is a diversity of colour, and, we should embrace it.
VMCIMCCFIT. Demand our. respect. It is what Canadian aviators want and expect.
Well, maybe not in Alberta.
I think if you read my post carefully you would noticed I mentioned the transition from VMC to IMC was not instantaneous....
As to the go/no go decision , I am just tired of hearing pilots get themselves in a bind, and when it ends up badly claim they felt under pressure. My experience in decades of management was that the challenge was to hold the young fools back from trying to get themselves killed. That pendulum seems to have swung the other way in the last few years as pilots were refusing trips because it was to windy or there might possibly be, maybe , according to the GFA a cloud in the sky.
In any event, the OP was asking why pilots crash under certain curcumstances. Quite a bit of literature on the subject, but nothing I have read that offers some sort of solution.....other than TC’s. SMS for small operators, of CSO required seminars....both of which are a roaring success, as we all know.
Victory
Re: VFR and CFIT
Post by Victory »
My friend from my first dock job transitioned from VMC to IMC. Goes by Stella now. But he'll always by Steve to me.
