Rouge upgrades seats and service
https://ca.travelpulse.com/news/airline ... rvice.html
So maybe the plan is to fold Transat into rouge?
- Daniel Cooper
Re: Rouge upgrades seats and service
That is what many people predicted. There could also be a three tier product with Transat as an ULCC but that seems a bit complicated.
Is there anything to stop Air Canada getting Swooped like WestJet did?
That's good. Why did WestJet not have such language? Just didn't foresee they execs betraying them?
- Jean-Pierre
Just curious how many pilot are currently at Rouge ie. how many are required to operate at the Rouge current size?
768Jean-Pierre wrote: ↑Fri May 24, 2019 8:27 am Just curious how many pilot are currently at Rouge ie. how many are required to operate at the Rouge current size?
- Jean-Pierre
Almost same number as Transat. Interesting.
They can’t. However Transat could largely replace Rouge. Rouge is already at its max Widebody size allowed by contract. They don’t even have much more room for narrow bodies. There is even a specific clause in the contract stating a merger can not be used to increase the size of Rouge. They could however park an equivalent number of 767’s at Rouge as Transat has 330’s.C-GGGQ wrote: ↑Fri May 24, 2019 7:15 am https://ca.travelpulse.com/news/airline ... rvice.html
Initially AC needs the lift with the 737 out of service. I suspect that down the road, a year or two out, Rouge parks the 767 and morph into Transat. These two entities are competitors with significant overlap.
The AC pilot group doesn’t have an appetite to see the low cost division expand. Nor do I think AC has the need or desire for a leisure carrier twice its current size. Rouge/Transat, whatever it’s called a couple years out, won’t be much larger than Rouge is today. Unless of course the contract is altered. But again unless AC wipes out the two tier pay scale? I doubt it. To be clear I doubt AC will be willing to get rid of the two pay scales.
So my guess is status quo for now with Rouge 767 reductions down the road as it morphs into Rouge/Transat.
It will certainly take care of AC’s current and projected pilot shortfall though. Two birds with one stone. This is why the bottom half of the AC pilots are so concerned. What they thought was to be hiring below them may turn into integration above them.
They never had a contract at the time just an agreement that never held much weight.
Yes, I suppose I worded that poorly. That's in essence what I was getting at.Fanblade wrote: ↑Fri May 24, 2019 9:10 amThey can’t. However Transat could largely replace Rouge. Rouge is already at its max Widebody size allowed by contract. They don’t even have much more room for narrow bodies. There is even a specific clause in the contract stating a merger can not be used to increase the size of Rouge. They could however park an equivalent number of 767’s at Rouge as Transat has 330’s.C-GGGQ wrote: ↑Fri May 24, 2019 7:15 am https://ca.travelpulse.com/news/airline ... rvice.html
I agree they can't use a takeover to grow Rouge, but by the same token, the contract stipulates that all AC flying above the scope limit must be done by ACPA pilots. IOW, they could not keep Air Transat separate without an LOU. Once AC owns TS, ACPA owns the flying.
Now correct me if I'm wrong, but the general thinking is that Transat cannot get merged into Rouge because of
1: the ratio
2: acpa "owns" the flying.
For 2: that will only hold true if the representation vote stays with acpa correct?
For 1: wouldn't the ratio just have to stay the same? As in rouge can't take ALL the planes but can in fact "grow" as long as the mainline fleet grows equally?
1: the ratio
It's completely contractual. It does not matter who the representative is.C-GGGQ wrote: ↑Fri May 24, 2019 12:11 pm Now correct me if I'm wrong, but the general thinking is that Transat cannot get merged into Rouge because of
1: the ratio
Acquisition can not be used toward Rouge growth.
Rouge can not grow without ACPA agreeing.
If you are not on the AC pilot seniority list you can not fly aircraft above 80ish seats on behalf of AC.
If the acquisition goes through the two groups will integrate. If the acquisition goes through:
The combined Rouge/Transat fleet will have to shrink particularly the widebodies. Probably the Rouge 767.
Or
Transat will merge mostly with mainline.
Or
ACPA would agree to let Rouge /Transat grow in exchange for something.
That's all the options there are. They are all a possibility. I think the least likely is number 3.
I don’t believe they can just sub 330s for the 767s at rouge just yet. They can only do that if the 67s or 330s at mainline are replaced by “new” as defined, aircraft at mainline on a 1 for 1 basis. And only after all 62 787/777s are at mainline.Fanblade wrote: ↑Fri May 24, 2019 9:10 amThey can’t. However Transat could largely replace Rouge. Rouge is already at its max Widebody size allowed by contract. They don’t even have much more room for narrow bodies. There is even a specific clause in the contract stating a merger can not be used to increase the size of Rouge. They could however park an equivalent number of 767’s at Rouge as Transat has 330’s.C-GGGQ wrote: ↑Fri May 24, 2019 7:15 am https://ca.travelpulse.com/news/airline ... rvice.html
Maybe depending on age of transats fleet they can stick some at mainline and swap others in at rouge. But Transat only has 20 now as it is, so you are still stuck with a few 767s.
The 62 787/777 happens when the last 787 arrives. When is that? Or has it already happened
Based on the annual/quarterly report we get the last 2 this year. I think only 1 left now.
But now that we have all 62 they can only swap to 330s at rouge on a 1 for 1 replacement with “newer” (less than 10000 hrs) widebody replacements at mainline for the mainline 767 and or 330s.
Unless we get the 13 options and go to 50 787s. There are a few different provisions.
