Transat Votes Yes for Air Canada Acquisition
Post by ahramin » Fri Aug 23, 2019 9:23 am
95% yes vote. Now that we know it's happening, I look forward to knowing what is happening.
DanWEC
Re: AT Votes Yes for AC Acquisition
Post by DanWEC » Fri Aug 23, 2019 9:40 am
Something I've heard from the AC side is the very real possibility of Transat completely replacing Rouge....
Mainline needs pilots, so Rouge crew would slide over to mainline. Solves that.
Rouge 319 and 767's at end of life would be retired and replaced by Transat's fleet with no changes to scope.
Transat pilots would either keep the existing contract or start operating under Rouge's. Or be a reneg and likely a blend of whatever are the high points are between the two.
Transat already has the approval, slots and gates that support the leisure type of operation.
This to me makes more sense than Transat suddenly becoming mainline, unfortunately.
Thoughts?
'97 Tercel
Post by '97 Tercel » Fri Aug 23, 2019 9:43 am
Who knows what they'll do with their airplanes but I think AT pilots will be AC pilots in less than a year (whether they start at Rouge or not)
Mapleflt
Post by Mapleflt » Fri Aug 23, 2019 9:45 am
And those shiny new 737 max's park in the desert just became Neo's
Hangry
Post by Hangry » Fri Aug 23, 2019 10:02 am
Thoughts?
Mainline and Rouge pilots are all ACPA pilots. Rouge pilots have bid not to be mainline pilots.
Any kind of forced “mainlinezation” of said pilots would be met with fierce resistance.
sanjet
Post by sanjet » Fri Aug 23, 2019 10:06 am
Not according to the last equipment bid.
Mapleflt
Re: Transat Votes Yes for Air Canada Acquisition
Post by Mapleflt » Fri Aug 23, 2019 10:17 am
Which was likely put out before the AT approval announcement
sanjet
Post by sanjet » Fri Aug 23, 2019 10:20 am
I can assure you, AC management is years ahead of everyone else including employees/pilots.
Mapleflt
Post by Mapleflt » Fri Aug 23, 2019 10:26 am
Exactly, and play their cards very close
Victory
Post by Victory » Fri Aug 23, 2019 1:42 pm
