Boeing allegedly Misled FAA on MAX certification.
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, I WAS Birddog
C.W.E.
Re: Boeing allegedly Misled FAA on MAX certification.
Post by C.W.E. »
This is really a sad episode for a company that has built so many good products and has to be hurting shareholders.
tailgunner
Post by tailgunner »
There were some posters who wanted to blame the pilots, wondering what they think now?
goingnowherefast
Post by goingnowherefast »
Boeing used to have a great reputation of building fantastic aircraft designed for pilots. They were known as a "pilot's airplane". Now their reputation is that they build the cheapest thing they can get certified to appease share holders, quality and safety be damned.
Dry Guy
Post by Dry Guy »
Don't forget the media is wrong about just about every aviation story (and probably everything else too). One reporter misunderstands something then all the other journalists reprint it and cite the first one as their source.
W5
Post by W5 »
Fairly long read (10 min.), it includes the exchange:
https://theaircurrent.com/aviation-safe ... velopment/
boeingboy
Post by boeingboy »
They still splashed a serviceable airplane from a salvageable situation.
Rationally tell me please, without jumping on the bandwagon or joining the herd mentality - how does this change anything?
Capt. Underpants
Post by Capt. Underpants »
boeingboy wrote:
Fri Oct 18, 2019 6:39 pm
I’d prefer to wait until the investigations are finalized before making such conclusions.
C.W.E.
Post by C.W.E. »
It looks like it is getting more embarrassing for Boeing as more info comes out.
mixturerich
Post by mixturerich »
Mapleflt wrote:
Fri Oct 18, 2019 4:27 pm
Boeing is just the one that got caught :roll: :wink:
Exactly, look at most politicians, or all those actors and the #metoo movement. You really think Airbus or Bombardier have their hands clean? Keep dreamin’.
tbaylx
Post by tbaylx »
Capt. Underpants wrote:
Fri Oct 18, 2019 7:15 pm
All the relevant parts of the investigations have been concluded and released. Nothing else is coming that will significantly change the narrative.
BTD
Post by BTD »
Dry Guy wrote:
Fri Oct 18, 2019 4:38 pm
The raw texts and emails have been released. We can form our own judgement without journalists’ narrative. Conclusion = very bad.
goingnowherefast
Hard to call it a "serviceable airplane" with erroneous MCAS activation. The situation might have been salvageable had the crew been adequately trained on the malfunction.
The only thing this changes is to show how deep the systemic failure is.
It was not a serviceable airplane.
It had a system that was driving a primary flight control to an unsafe situation as the result of a failure of a single component.
They (Ethiopian) did exactly what Boeing told them to do and were left with an airplane dangerously out of trim and were unable to manually trim it.
Tell me, rationally, what would you have done differently at that point in time? Roll it inverted like Maverick and Denzel?
No. It’s only because pilots in North America have the autopilot on from takeoff to touchdown in most cases that this problem didn’t rear its ugly head here.
The FAA knows it. Boeing knows it. The worldwide aviation regulating bodies know it. The customers know it. It’s not the first time, either.
boeingboy
Post by boeingboy »
OK - my bad. When I said serviceable, I meant the aircraft was capable of flying perfectly fine. It was serviceable until a bird took out the AOA probe.
Yes - this is true. It still does not make #1 untrue.
No - They did not do exactly as Boeing had instructed - which was a big part of the problem.
Really - This is a rational question??
Rubbish. No matter who flies it (Not just North America) First - they all fly it the same.... and second - The system will not engage (or if it is already engaged - will disengage) if this problem arose. Everybody would be in the same boat.
GRK2
Post by GRK2 »
Then there's that "small" issue of leaving the thrust levers at MCT (or worse...) for much if not all of the flight until that speed was waaaay beyond any normal realm. Pretty huge oversight. Even with all the conflicting warnings, someone still has to aviate. (This is an understatement...) Serviceable aircraft? Nope. Well handled by the crew? Same answer.
GRK2 wrote:
Sat Oct 19, 2019 11:39 am
How would you suggest one should attempt to climb with a (perceived) non responsive elevator?
GRK2
Post by GRK2 »
By your response I am quite sure you either have no related experience, (that's ok, it's not a bad thing) or you didn't read the report(s) in which there was a lot of criticism leveled at the crew for their serious mismanagement of the basics of aircraft handling. Go find it and read the part about auto throttle and speed management.
GRK2 wrote:
Sat Oct 19, 2019 12:44 pm
It would be nice if arguments get attacked instead of the person making the argument.
My point is that you can only get an airplane with a stuck nose down trim/elevator to climb by increasing speed. It would be better to overspeed and fly, than to crash with the speed within limits.
You can maybe make an argument about the trim cut out switches, but faulting them for not reducing power when they are in an uncontrolled descend is silly.
I would like to read the reports that criticize the power lever handling; where would I find them?
BTD
Post by BTD »
I highly doubt that it was a conscious choice to leave the thrust up. I’m willing to bet it was an oversight but one that I understand.
I’ve said it before and I still believe it. I think this was a human factors accident. And I think that a substantial number of pilots around the world end up just like the Ethiopian crew did. Western or otherwise. We have had enough western pilots fly actually perfectly serviceable aircraft into the ground under much simpler circumstances. Human cognitive resources are limited. Broadly we are all similar in the way we respond to multiple stimuli competing for those cognitive resources.
The airplane put them in a precarious situation and then through a lack of foresight and seemingly negligence, it did everything possible to f*ck up the human pilot’s ability to take in and analyze the data and form a diagnosis.
There is still an argument to be made regarding worldwide pilot standards, but this situation is not the one to hang the hat on to make that case. Boeing screwed up huge, and these emails and texts are less relevant to the Mcas itself, but rather the state of the culture and work pace going on inside the company at the time.
I’d still like to read those reports. Anyone?
boeingboy
Post by boeingboy »
I suggest you become familiar with the facts before stating claims like this - they were not in an uncontrolled decent until the last 10 secs or so. The throttles were left wide open since they started the takeoff roll.
boeingboy wrote:
Sun Oct 20, 2019 3:43 am
I suggest you do the same.
Looking at the graph in the preliminary report, they were close to/at vmo from the moment the mcas started to trim down, attempting an uncommanded descend. The crew fought it by force. How would it make any sense at all to reduce power when the plane wants to descend and you want to climb?
When they couldn't hold it anymore vmo was grossly exceeded.
Curiousflyer
Post by Curiousflyer »
photofly wrote:
Sat Oct 19, 2019 1:24 pm
There will be none. The power levers were handled perfectly well. With the nose down trim the only thing keeping the bird in the air was airspeed.
