I have some but probably not as much as you guys. The experience I have however was largely focused on demonstrating certification requirements for exactly this. I do have a fair amount of experience in twins certified under part 23 but above 6,000 lbs/turbo-props.Big Pistons Forever wrote: ↑Thu Nov 12, 2020 9:02 pm From the Piper Seminole POH, Emergency Procedures , Engine Failure After Takeoff
“In certain combinations of aircraft weight, configuration, ambient conditions and speed, negative climb performance may result. Refer to One Engine Inoperative Climb Performance chart,”
I am with Pelmet. Procedures for large aircraft which have demonstrated capabilities to continue a takeoff after an engine failure should not be extrapolated to small piston twins
Aux. How much experience do you have flying light piston twins ?
Like I said before, I do not exclude the possibility of putting it down after becoming airborne. But there may not be runway in front to safely land on. And again, it comes down to knowing the aircraft you fly and having mental gates on actions to be carried out in case of emergency. That was the point I was trying to make before the noise started.
Pelmet: here’s the FAR I was referring to:
Sec. 23.67 — Climb: One engine inoperative.
(a) For normal, utility, and acrobatic category reciprocating engine-powered airplanes of 6,000 pounds or less maximum weight, the following apply:
(1) Except for those airplanes that meet the requirements prescribed in §23.562(d), each airplane with a VSOof more than 61 knots must be able to maintain a steady climb gradient of at least 1.5 percent at a pressure altitude of 5,000 feet with the—
(i) Critical engine inoperative and its propeller in the minimum drag position;
(ii) Remaining engine(s) at not more than maximum continuous power;
(iii) Landing gear retracted;
(iv) Wing flaps retracted; and
(v) Climb speed not less than 1.2 VS1.
For a stall speed of less than 61 kts, the climb/descent gradient just needs to be determined (no minimum climb gradient).
23.562 is, I think, related to safety occupant.
