YYC Base with Jazz
YYC Base with Jazz
I have a ground school with Jazz on June 25th, I'm assuming I will get a Toronto or Montreal base. How long do you think it will take to get a Calgary base and how hard is the commute. I'm thinking 6-9 months for a YYC base.
- twinpratts
Re: YYC Base with Jazz
Depends on how many in your class above you want YYC.R2000/1830 wrote:I have a ground school with Jazz on June 25th, I'm assuming I will get a Toronto or Montreal base. How long do you think it will take to get a Calgary base and how hard is the commute. I'm thinking 6-9 months for a YYC base.
I'm just in sim training now and missed the standing bid for yyc by 2 days. I had a bid in, than however my fiance got a job in yyz so I pulled out my bid. 2 Days later a new standing bid came out and a guy that is the groundschool below me that had just started ended up with the position in yyc.
So if you lucky, you won't even be out of training. If your not, than maybe 2 months
With the high cost of living here in Calgary, unless you have accomodation already, you might want to give YYC a miss until your salary level rises to one that can support a 1400.00 single bedroom apartment (if you can find a vacancy)R2000/1830 wrote:I have a ground school with Jazz on June 25th, I'm assuming I will get a Toronto or Montreal base. How long do you think it will take to get a Calgary base and how hard is the commute. I'm thinking 6-9 months for a YYC base.
- Rank Moderator
