Thunder Mustang destroyed in crash at Reno - video of crash
N151G Thunder Mustang
First, the pilot walked away from this crash!!!!! Even waving to the crowd as
he walked away from his wrecked airplane!!
Aircraft had just departed and experienced mechanical problems and made an emergency
return to the field, bounced, cartwheeled, and broke apart!!
Click Here for Video and click the enlarge button to watch.
Photo of N151G
Photos of crash sequence
Photo of N151G
Re: Thunder Mustang destroyed in crash at Reno - video of cr
Wow, glad he walked away. Looks like if he didn't cartwheel where he did he may have taken out the whole Snowbird fleet.
Wow that is intense! Thanks for making that second thread, if not for that thread I would not have seen this. This topic should be on the General Comments section IMO.
Amazing series of photos and outcome!
(By the way, likely your best friend for finding posts on the board is this link at the top right side of the page:
View new posts
Works like a charm and you don't have to worry about what section a thread is in.)
View new posts
That is amazing!!
Between this crash, and the one with the glider, these are very lucky pilots to walk away from major crashes.
News video captures the cartwheeling, then introduces you to the pilot
as he describes, something in the engine broke, he climbed to 2000 feet
and the engine quit, he recalls right up to the wingtip hitting, then he said
next thing he knew he was just sitting there!
His biggest complaint, he lost his glasses!!!
http://www.q13fox.com/news/kcpq-092110- ... 6191.story
Was there and saw it happen. As a Monday morning quarterback it appears he srewed up pretty bad. He blew the engine coming around the last pylon on the home stretch. He was now on a downwind for the runway when he pulled up to gain altitude but instead of turning for the runway after that, he carried on way to far downwind considering he would be turning final into about a 40kt headwind. Once he started his turn for final he was to far out and way to low to complete it. The real sad part of this was they cancelled the Unlimited Race which was up next as the final race of the day. For anyone who doesn't know the Unlimited Class is the non-restrictor plate Nascar Race of Air Racing.
There were also a few other close ones throughout the weekend. No injuries, just some bent metal and bruised egos.
I was there as well, so all I can add is that he put the gear down way too early killing the glide. And he also could use the other runway, but had to make the call a bit earlier. Easy to make these comments sitting on the ground though.
