Time on AvCanada is messed up.
Moderators: lilfssister, North Shore, ahramin, sky's the limit, sepia, Sulako, I WAS Birddog
jpilot77
Post by jpilot77 »
The times are messed up again on the message boards. I have mine set to UTC-5 (eastern standard time) yet it is showing 5 hours in advance. Also when you set it to Zulu time the error persists (it doesn't show the proper Zulu time).
Anybody else having this problem?
Adam Oke
Re: Time on AvCanada is messed up.
Post by Adam Oke »
Yup. I think this is typically due to hosting server error.
--Air to Ground Chemical Transfer Technician turned 3 Bar Switch Flicker and Flap Operator--
GyvAir
Post by GyvAir »
I've been noticing it fluctuating from one day to the next all over the clock from -2 to +5 ever since the switch to the new server.
Gorgons
Post by Gorgons »
Oh man... the secret is finally out, the server is located on the space station!
avcanada
Rank Admin
Rank Admin
Post by avcanada »
Test
DanWEC
Post by DanWEC »
I see the above post an hour ago as at 1:16am. It's currently 2023 here, EST.
Edit- Time for this post showing up as 2:24am, Sunday.
GyvAir
Post by GyvAir »
Gorgons wrote:Oh man... the secret is finally out, the server is located on the space station!
Oh man! And all this time I was worryied that it was located in the white, windowless flower delivery van that's always parked on the street a couple houses down..
black hole
Post by black hole »
I don't understand all the buzz. I was happy with yesterday, today and tomorrow!!??
BH
Colonel Sanders
Post by Colonel Sanders »
It's actually quite tricky to synchronize multiple
machines (GPS is wonderful) but you still have
to worry about crossing time zones and the IDL
and the discontinuity and repetition arising from
the change to daylight savings time and back again.
I have had good results with storing GMT internally
and applying TZ/daylight offsets for user display.
Edo
Post by Edo »
The server time is correct, its just taken the daily average of the time you waste on here multiplied it by 3.14159265359 divided it by the total number of useful posts you have ever made and expressed it in 24hr format.
Mine seems to be slightly more accurate that my Breitling.
leftoftrack
Post by leftoftrack »
Edo wrote:The server time is correct, its just taken the daily average of the time you waste on here multiplied it by 3.14159265359 divided it by the total number of useful posts you have ever made and expressed it in 24hr format.
That you bought in Tijuana for $9
jpilot77
Post by jpilot77 »
A simple solution to get the correct time for me was to set it to Aleutian time GMT +10, this gives me the correct time for eastern standard time.
