Ottawa RIver Departure under the Bridge
Re: Ottawa RIver Departure under the Bridge
I think the lesson here is obvious. When ever you do something unusual, somebody will;
1) Take a video of it
2) Post the video on social media
3) Comment on your actions on Avcanada
It is a new world......
For the record my 02 cents are as follows
If the pilot deliberately manoeuvred his airplane so that he had to tskeoff by going under the bridge than I think he was foolish.
- Shiny Side Up
But only foolish in the idea that someone is going to be unhappy about it and complain. Personally I'm a big proponent of the Colonel's one guideline to flying, but increasingly the list of things you shouldn't do only because they'll frighten the unwashed masses, won't understand, and be really unhappy about is getting longer by the day. Personally I'm starting to get tired of how its going and its time to start pushing back. To that end, I'd encourage a lot of people to take off under that bridge, so it ceases to become unusual, and one could make a solid argument that any reasonable and prudent pilot would do it.
- Colonel Sanders
Unsurprisingly, I have had many discussions
with Transport. More than once, I have told
them:
"Just because it's unusual, doesn't make it
illegal or dangerous"
The vast majority of pilots, will assume that
something unusual must be somehow
illegal. Or dangerous. Predictably, we can
see Rockie trying to shoehorn CAR 602.01
onto this one, ignoring the posts from many
other float pilots that this is routine, in less
sensitive and delicate parts of the country.
The way the regulations work, is that if it
is not specifically prohibited, it is therefore
permitted, modulo CAR 602.01, which is
sort of a prize for originality and creativity.
them:
The nice thing about regulations is that they keep people like Hedley in check. Without them there would be no restraint, and adrenalin junkies in the air, on the water and on the roads would be even more of a hazard than they already are.
Who gives a rat's ass if float pilots on here defend what this pilot did just because they do it in bumf**k nowhere? Do it around people and they will likely have something to say about it whether you think it's valid or not. Ignore them at your own foolish expense.
- Colonel Sanders
Sorry I hurt your feelings, honey.
40 years of flying, and not one dented
airplane, which is the objective, in case
you hadn't noticed.
you hadn't noticed.
- Rank Moderator
Can you guys get a room, and hash out your differences in private, please?
Happiness is V1 at Thompson!
No it was foolish because as I understand the event he had the option to takeoff without passing under the bridge but manoeuvred so that he had to pass under the bridge. So if you have a choiceShiny Side Up wrote:But only foolish in the idea that someone is going to be unhappy about it and complain.
1) takeoff and then fly under a bridge, or
2) takeoff with a clear departure path,
And you choose choice 1 then I think you are being foolish. However if wind, traffic, and other departure path obstacles mean that in your judgement the best takeoff flight path would necessarily involve passing under a high bridge ( or much more commonly wires ) then that would be the correct course of action and you would FWIW get my support.
Pushing back against the man is IMO, not in itself a good enough reason to do something......
CS,
Unlike computer programming, the world isn't black and white. What is acceptable in parts of aviation is not in other. For example, for air displays, aerobatics, a head-on takeoff followed by an immelman is probably acceptable/within the bounds of normality. But, for a 704 operation it is not.
With experience in your field, you start developping judgement, just like you develop ethics when you grow up: you start having an idea of what is right and what is wrong, regardless of legalities. That is how you can decise whether or not what you are about to do is normal/acceptable. If it is not but is still legal, you better have a good reason, otherwise you bet that a 602.01 is in order.
Going for the deck at corner
- Colonel Sanders
I will admit that I do not suffer fools
gladly, nor am I impeded by false
modesty, which I consider the refuge
of the incompetent.
This is a far worse sin, than any contravention
of the CARs.
See the final episode of Seinfeld, where
the entire cast is convicted of "criminal indifference".
of the incompetent.
of the CARs.
- Prairie Chicken
I fully expect TC are investigating. 602.01 seems likely. 602.13(1) is a possibility (no t/o within a built up area). The outcome will of course depend on what the investigation reveals, but on first blush it looks like a blatant violation of 602.01.
Assuming the a/c is marked as required, the RO will soon be receiving a letter requesting he provide the name & licence number of the pic.
The most disturbing aspect of this thread is how many of you see nothing wrong with it. If this was the action of a 'reasonable & prudent’ pilot … folks, we’re in a lot of trouble.
Prairie Chicken
Do you invest in anything other than overpowered penis compensators Hedley? If you do you might remember reading this:Colonel Sanders wrote:40 years of flying, and not one dentedairplane, which is the objective, in caseyou hadn't noticed.
"The performance represented is historical; past performance is not a reliable indicator of future results"
- Cat Driver
I was under the impression that sea planes use the Ottawa river for landing and taking off.....not necessarily under that bridge though.602.13(1) is a possibility (no t/o within a built up area).
Does anyone here know if they use that water between the bridges?
I know in Vancouver we have been flying off the river for decades and that is a built up area.
This whole problem could have been avoided had the pilot stayed on the water for another eight seconds or taxied closer to the bridge before starting the take off.
- Colonel Sanders
Really. I suppose you have never tried topast performance is not a reliable indicator of future results
get any insurance for anything? You know,
on the form where they ask you for your
history of claims?
It's good to know that you know more about
this, than every actuary that has ever worked
at every insurance company.
- Prairie Chicken
Cat, I don't know that territory which is why I said it was a possibility. That portion of the river (without the bridge) may be certified, or may have been determined not to be in a built-up area. Either way, the t/o/ or a landing wouldn't be contrary to 602.13. Certainly there are many parts of the country where ops from waterdromes are perfectly legit.
Prairie Chicken
- Cat Driver
First off Prairie Chicken I am not defending what that pilot did because with just a bit of effort he/ she could have avoided this whole shit storm.
In today's electronic world there is no privacy and someone is bound to record and post it on the internet, the news media will immediately blow everything out of proportion to the actual danger involved which will leave you hanging out to dry under 602.01 a place where I would never want to be because that CAR is a real catch all and open to interpretation based on who may want to see what.
As to the actual danger to life in that take off I don't see there was anymore or maybe even less than those people boating without flotation devices, how come the media missed that?
- Prairie Chicken
I've missed you too Cat.
Prairie Chicken
- Cat Driver
Your not focusing on all those dick measuring posts BPF got going about me are you?I've missed you too Cat.
- Prairie Chicken
Nah, but I'm sure BPF wouldn't lie on this here forum.
Prairie Chicken
- Cat Driver
As ive said before there are 3-4 float planes that are docked a little to the east of that bridge and which use the river east. There was previously a few docked west of the bridge but ive not seen any lately.
I grew up in victoria and the float plane operations were 'interesting' to say the least so this does not seen that unusual to me but you could not pick a worse crowd to scare than the rowing club.
