August Equipment Results
Re: August Equipment Results
my friend said this, and my friend said that, but she or he also said that!
They might use the Mont Royal Simulator?
Well using something like an allsim would definitely reduce a full level D sim cost which will be skyrocketing going forward. I wonder if they would move the whole Sim process of the interview to strictly a GA level sim eval. Interesting
Yup. Mount Royal ALSIM it was. I did both in one week.
Magnetron would you mind sending me a DM! Just a few questions about the sim process
Alsim is a good machine. I have about 15 hours in one.
Someone I know has his full motion booked before the Calgary one. Perhaps it's just for redundancy sake, a second eye, more or less.
Update on the two SIM thing.
From what I've been told its a test to see how the non motion compares to the full motion. They are running about 20 people through both right now to see how the end results compare. IE; if 8/10 pass the full motion, and only 10/10 pass the non motion or vice versa. They want to see how the end results compare between the two. They want to move fully to non motion to save money as it's about 1/4 the cost per hour and frees up the D's for LOFTS and ground schools and this is the first step in some research to see if it's viable.
It's not a permanent thing. There are some people who have gone through the interview two weeks ago that have two sims and others that has an interview last week that only have one.
