YWG Terminal IFR Offers
Just a heads up that offers are coming out. Just got my offer for Terminal IFR starting July 1st. Good luck everyone!
navcanhopeful
Re: YWG Terminal IFR Offers
Good for you. Its only a 2 person class to start, so people shouldn't get their hopes to high.
Wait what?navcanhopeful wrote:Good for you. Its only a 2 person class to start, so people shouldn't get their hopes to high.
navcanhopeful
You're being specifically trained for YWG terminal unlike the generic class where you can be broken off into 1 of 5 specialties. You already know yours, 2 of you will start from the beginning for generic terminal IFR, then once completing that a senority bid will join you for your specialty terminal training.
The terminal course is a generic course. You are just going to be assigned to a terminal unit. Many ACC's have more than one.navcanhopeful wrote:You're being specifically trained for YWG terminal unlike the generic class where you can be broken off into 1 of 5 specialties. You already know yours, 2 of you will start from the beginning for generic terminal IFR, then once completing that a senority bid will join you for your specialty terminal training.
navcanhopeful
Incorrect. YWG ACC only has 1 terminal unit. The rest are intergrated into the specialties. At first it will be the generic portion, after that you will be trained for YWG terminal.Braun wrote:The terminal course is a generic course. You are just going to be assigned to a terminal unit. Many ACC's have more than one.navcanhopeful wrote:You're being specifically trained for YWG terminal unlike the generic class where you can be broken off into 1 of 5 specialties. You already know yours, 2 of you will start from the beginning for generic terminal IFR, then once completing that a senority bid will join you for your specialty terminal training.
There is only one Terminal unit in YWG. I know that. What I said was that they still do the same Generic Terminal course as every other ACC. You aren't trained off the bat just for YWG. You still do the 5-6 month national Generic Terminal course and then move to specialty training. For people in ywg this would be for sure YWG Terminal but they could also be sent to other subunits depending on skills, staffing and other causes. The Generic course, Enroute or Terminal, still remains a Generic course and you technically could be sent anywhere for the above mentioned reasons. It is rare but it can happen.navcanhopeful wrote:Incorrect. YWG ACC only has 1 terminal unit. The rest are intergrated into the specialties. At first it will be the generic portion, after that you will be trained for YWG terminal.Braun wrote:The terminal course is a generic course. You are just going to be assigned to a terminal unit. Many ACC's have more than one.navcanhopeful wrote:You're being specifically trained for YWG terminal unlike the generic class where you can be broken off into 1 of 5 specialties. You already know yours, 2 of you will start from the beginning for generic terminal IFR, then once completing that a senority bid will join you for your specialty terminal training.
Ah gotcha, thanks for the info.navcanhopeful wrote:You're being specifically trained for YWG terminal unlike the generic class where you can be broken off into 1 of 5 specialties. You already know yours, 2 of you will start from the beginning for generic terminal IFR, then once completing that a senority bid will join you for your specialty terminal training.
Congrats on being accepted. I am currently in the IFR enroute class. If you want to know anything more about starting up at the Winnipeg ACC you can msg me.
