Livin the dream 3
flyinhigh
Livin the dream 3
Post by flyinhigh »
https://youtu.be/5-knyUBbpgI
I personally like the hotel shuttle sequence
gwagen
Re: Livin the dream 3
Post by gwagen »
flyinhigh wrote:https://youtu.be/5-knyUBbpgI
Was my favourite part!
Have had very similar experiences in airport shuttles.
What is that speed brake complaint they refer to?
Jean-Pierre
Post by Jean-Pierre »
Using any kind of brake waste fuel. If you had planned properly you wouldn't need it.
Black_Tusk
Post by Black_Tusk »
Jean-Pierre wrote:Using any kind of brake waste fuel. If you had planned properly you wouldn't need it.
Except when your whole descent gets screwed up by alt restrictions or headings because of traffic.....
nightbird
Post by nightbird »
It's a control surface. Use it when you need it, period.
JasonE
Post by JasonE »
Does that include the the ones that stop you from running off the end of the runway after you touchdown? :)
mantogasrsrwy
Post by mantogasrsrwy »
I never use the money stick unless ATC makes me.
mantogasrsrwy
They are free once you touch down unless you need power to make the taxiway.
Dockjock
Post by Dockjock »
If you're at idle thrust how does a speed brake affect fuel consumption?
atphat
Post by atphat »
It doesn't. There is nothing more annoying sitting there when the boards should be out and they aren't. Far more annoying than using them when you don't really need them. Planning properly. Lol. Ok. Maybe if all you do is fly into Halifax.
CL-Skadoo!
Post by CL-Skadoo! »
Sometimes my descent planning is so bad that I consider sticking my head outside the window.
Meatservo
Post by Meatservo »
CL-Skadoo! wrote:Sometimes my descent planning is so bad that I consider sticking my head outside the window.
I'm with you. Descent planning is not my forte. Thank god for the speed brake.
I found this latest "living the dream" to be the best one so far. It was pretty funny. And accurate. Pretty much a documentary. Well done.
FICU
Post by FICU »
The shuttle scene depicted many rides in Montreal... too funny! And... Keep those damn fingers off the screens! Point... don't touch!
Instructor_Mike
Post by Instructor_Mike »
Dockjock wrote:If you're at idle thrust how does a speed brake affect fuel consumption?
In theory if you need your speed brakes now then there was a time where you could have used less power earlier on. Less power earlier means less fuel used.
Of course it's hard to plan for all that. Even a few knots of wind can throw off your plan.
In the king air I fly we joke about going props max (full fine) as the props of shame since you shouldn't need to do that if you plan it right. It's a tool to use when needed so as much as we joke with each other, you use what you need.
