Jazz Hatters
Jazz Hatters
Serious question to the numerous Jazz folk who refuse to wear the hat. What other aspects of your job are you willfully non compliant just because you don't like it? FFOD checks? Stable approach criteria? How far does it extend?
Re: Jazz Hatters
I feel the maintenance needs extra work to do. So at least once a day I try and over-speed the gear or flaps.
Someone's dislike of a hat is a bit of a stretch when attempting to compare it to stable approaches. It's not a safety thing, it's barely even a professional appearance thing. WJ pilots still look professional, and they never wear hats. Do you feel Jazz should have their pilots wearing boxers or briefs?
Re: Jazz Hatters
I am a boxers guy myself, but I don't judge the brief wearers.
Personally, I've been wearing the hat less now because of the cheap velvet sweatband these new hats have. My hat is only a 30 knot hat, but the velvet still irritates my forehead.
- youhavecontrol
Re: Jazz Hatters
It's probably my greatest fear in applying for an airline job. I look terrible in ANY hat except a touque.
Re: Jazz Hatters
How is this a serious question when you assume that just because someone doesn't where the hat, (I don't like them, but I dislike the ballcap in the cockpit more), must mean they break every other sop there is. Lookout guys, his tie is 2 shades darker than the SOPs. Recipe for disaster! Have you contacted TC yet to start fixing this safety issue?
Re: Jazz Hatters
My new hat is uncomfortable. The same size new hat is smaller than the old one so it fits too tight and leaves a red band on my forehead. Picking up a new one when time allows. Bring the old one along for the ride to make it look like I care.
Re: Jazz Hatters
PS. Stupid comment from the original poster to assume we disobey SOPs because we don't wear an ill fitting Chinese made hat!
Re: Jazz Hatters
OP once again reaffirms this industry takes all types of people.
- YYZSaabGuy
Re: Jazz Hatters
Ah, yes........that critical link between sartorial correctness and flight safety. Often misunderstood, but still important.
Hats off to the OP for reminding us all.
Re: Jazz Hatters
Really? Touched a nerve I see. The uniform policy is pretty straightforward. No real room for interpretation. "Thou shall blah blah blah". Is it such a stretch to assume that if a "professional" pilot cannot follow something as easy as wear a hat, it may creep into other aspects of their job? Of course using stable approach criteria is hyperbole, but I assume by the time you get to Jazz you're a pro. Pros follow rules regardless of opinion. And when I see someone breaking such an easy rule I certainly don't think there goes a pro. In my opinion of course. Which you don't care about, because you can't even be arsed to wear a hat.Inverted2 wrote:PS. Stupid comment from the original poster to assume we disobey SOPs because we don't wear an ill fitting Chinese made hat!
Re: Jazz Hatters
No nerves touched here. I simply pointed out there are some issues with the fitting of the new hats whereas you inferred we operate our aircraft against the SOPs in a reckless manner which is untrue. Sounds like someone has hat envy.atphat wrote:Really? Touched a nerve I see. The uniform policy is pretty straightforward. No real room for interpretation. "Thou shall blah blah blah". Is it such a stretch to assume that if a "professional" pilot cannot follow something as easy as wear a hat, it may creep into other aspects of their job? Of course using stable approach criteria is hyperbole, but I assume by the time you get to Jazz you're a pro. Pros follow rules regardless of opinion. And when I see someone breaking such an easy rule I certainly don't think there goes a pro. In my opinion of course. Which you don't care about, because you can't even be arsed to wear a hat.Inverted2 wrote:PS. Stupid comment from the original poster to assume we disobey SOPs because we don't wear an ill fitting Chinese made hat!
Re: Jazz Hatters
Until they give me a new one with new velvet, it's staying in my hand. I got a nasty rash last week when it was 30* outside and since then it's no longer being worn. The company and unisync are aware of the issue, and until ALPA presses them to fix the problem it will likely keep dragging on. Just like the pants.
Re: Jazz Hatters
Not the company supplied ones.leftoftrack wrote:you dont wear your pants either?
- Jean-Pierre
- GreenBastrd
Re: Jazz Hatters
Seen a couple Jazz guys with beards too the other day, are you guys are allowed to sport trimmed beards now?
Re: Jazz Hatters
GreenBastrd wrote:Seen a couple Jazz guys with beards too the other day, are you guys are allowed to sport trimmed beards now?
Yes, mainline and GGN as well. Not sure about SKY.
Re: Jazz Hatters
Because you can, does not mean you should.
There are now numerous examples of Captain Highliner, and Captain Obvious walking around. They look unprofessional and ridiculous in my opinion.
Re: Jazz Hatters
In my experience it's quite the opposite. The ones who are worried about hats and sock colors are often the ones who are too smart - in their own minds - to follow the SOP and are invariably the ones who can't figure out basic CRM and crew building skills.
If I have a choice between the pilot with no hat and the pilot who thinks it's a good idea to run around telling everybody they should wear the hat, I know who I'd want flying my family.
Re: Jazz Hatters
I was driving 110 on the 401 today but I did wear my hat while I did it. Where do I fit in regarding intentional non-compliance and deviating from the rules?
Re: Jazz Hatters
mato wrote:I was driving 110 on the 401 today but I did wear my hat while I did it. Where do I fit in regarding intentional non-compliance and deviating from the rules?
Shame on you !! That kind of behaviour directly correlates to you flying STARs at 10kts above the speed limits.
Re: Jazz Hatters
I see what you did there. Nice one.co-joe wrote: My hat's off to you!
