Air Canada Rouge EGPWS warning at Huatulco
- confusedalot
Re: Air Canada Rouge EGPWS warning at Huatulco
Something is missing in this picture. Others are saying it was daytime with good weather, yet an egpws warning was produced? Controller authorized an altitude below safe ifr while on an ifr flight plan?
I will be interested to hear the outcome......sounds like either the controller made an incomprehensible criminally incompetent mistake or two people were sleeping in the cockpit, based on the sketchy information on this thread.
Confusedalot unless you are on radar vectors, terrain clearance is YOUR responsibility, not ATC. 6000' is a normal clearance into Huatulco and gets issued every day. Until this incident I'd never heard of an airline pilot who thought they could bust through the MOCA for their airway, MSA, and MORA altitudes because of a descent clearance.
- confusedalot
Explain to me like I was five years old, after 59 years on this earth, and after 39 years of flying, why I have never heard a controller clearing me below minimum altitude UNLESS I was cleared for a full approach?
I know huatulco, i know the terrain. Smartass.
- confusedalot
Oh and one more thing, every single airplane driver in this world knows that there is such a thing a minimum radar vectoring altitudes that the controller knows at any given place but you may perhaps not, since they are not published on jepps. So clearing an airplane to 6000 feet east of Hualtuco does not make sense, knowing the cumulogranites that just so happen to permanently be there.
So...are you going to question the controller on his minimum radar vectoring altitude in comfy yyz? You better have a good answer for that if you do.
Which brings me to my first point; something is missing in this picture, nothing more.
From reading the initial post, this incident appears to have occurred in non-radar environment. It would seem to me, that if in this situation and issued a descent at pilots discretion, it would be obvious to follow the appropriate published altitudes.confusedalot wrote: ↑Mon Feb 19, 2018 9:32 pm Oh and one more thing, every single airplane driver in this world knows that there is such a thing a minimum radar vectoring altitudes that the controller knows at any given place but you may perhaps not, since they are not published on jepps. So clearing an airplane to 6000 feet east of Hualtuco does not make sense, knowing the cumulogranites that just so happen to permanently be there.
- confusedalot
Yes of course, that would be the obvious course of action in a non radar environment, which is why I still think something is still missing in this particular writeup/event. One of those he said she said affairs where confusion was paramount?
I think some of you may be missing the following:-
Perfectly normal to get this kind of clearance.Air traffic control cleared the flight to descend to 6000 feet MSL at pilot's discretion.
I have flown into Huatulco many times. Once as a brand new FO my Captain interpreted exactly this clearance in exactly the same way while we were IMC. I quickly corrected them and we landed without incident (not saying I am a super pilot, just illustrating how easily and quickly the clearance can be confused based on 2 words). A thick Mexican accent never helps things either. Perhaps a better clearance would be “cleared 6000 feet with your own terrain “
Have not flown into Mexico but a question that comes to mind, are the terms “radar identified and radar services terminated” in use?
Perhaps the crew thought they were identified.
The descent into HUX is made in Non Radar environment. Like all of Central America, Mexico, you are on your own for terrain. Cleared for the approach doesn't mean you can just automatically descend down to whatever altitude you want to, you still need to respect minimum safe altitudes. In this case from NUDOS, the reference for safe altitude is the airway MEA, then the 25 NM sector altitude from the chart. The highest peak is essentially directly on the airway, if you descend down from NUDOS it won't take long to get to the same altitude as the ridge line.
Pretty serious lack of situation awareness, they are very lucky not to have had a hull loss.
I’d agree. A healthy dose of S.A!
Having operated into this airport many times in the past (C3,SSV days) this place along with OAX, MZO, PVR etc should make one extra vigilant with respect to terrain and procedural IFR clearances.
But they weren't just "cleared for the approach". They were cleared to descend to 6000ft at their discretion. I don't think this could happen in Canada, as ATC is prohibited from issuing clearances below the minimum IFR altitude unless within radar airspace.
http://www.navcanada.ca/EN/products-and ... 19.pdf#top
Isn't "descend at your discretion" normally reserved for VFR, at least in Canada? And doesn't ICAO regulate this phraseology?
That's not what your attachment says at all.CpnCrunch wrote: ↑Tue Feb 20, 2018 9:23 am I don't think this could happen in Canada, as ATC is prohibited from issuing clearances below the minimum IFR altitude unless being radar vectored.
"Within air traffic service (ATS) surveillance coverage, it is common for controllers to issue the minimum
vectoring altitude (MVA) when issuing direct routes. An MVA can be lower than a published minimum IFR
altitude (minimum sector altitude [MSA], minimum obstacle clearance altitude [MOCA], MEA, or area
minimum altitude [AMA])."
For our purposes the MVA is an appropriate minimum ifr altitude. No need to be on vectors for us to use it.
Sorry, I meant within radar coverage, which is what the PDF says. I've edited my original comment.
In this case they were in a non-radar envionment.
- confusedalot
But, but, but, on the Air Canada OTS thread, it has been declared that Air Canada only hires the faultless best.....and those who are not offered a position are substandard.
Sorry for the sarcasm, one of my chief character faults. Yeah, this is looking like a rather blatant situational awareness problem.
Just waiting for an AC shill to hijack the thread.
They seem to have mysteriously disappeared. I'll fill in.....No one hurt, on time....good job.
- confusedalot
absolutely, thank god the egpws did a good job and nobody got hurt.
Except that this was a non radar environment. Like in Canada in such a case, the pilots are responsible for terrain clearance......confusedalot wrote: ↑Mon Feb 19, 2018 9:32 pm Oh and one more thing, every single airplane driver in this world knows that there is such a thing a minimum radar vectoring altitudes that the controller knows at any given place but you may perhaps not, since they are not published on jepps. So clearing an airplane to 6000 feet east of Hualtuco does not make sense, knowing the cumulogranites that just so happen to permanently be there.
Minimum Altitudes to Ensure Obstacle Clearance
602.124 (1) Subject to subsections (2) and (3), the pilot-in-command of an IFR aircraft shall, except when taking off or landing, or when being radar-vectored by an
air traffic control unit, ensure that the aircraft is operated at or above
(a) the MOCA, when the aircraft is on an airway or air route; and
(b) the minimum altitude established by the Minister to ensure obstacle clearance and specified on an IFR chart, when the aircraft is within airspace in respect of which such a minimum altitude has been established.
- confusedalot
I think you are missing the point. We all know the rules, we all know not to fly into terrain, we all know, by reading the report comfy at our computers, that they were in a non radar environment.
Question is, did they realize that? If they did, and knowing the rules like everybody does, why did they do what they did?
Back to the situational awareness issue. Anyways, it's been debated to death.
Just flew into HUX the other day; my second time there ever, and my first in over 4 years. It was about a 6-7k ft ceiling over the mountains and basically SKC over the water.
The controllers are very clear, "Thick Mexican Accents" and all, that you are now radar service terminated. And even if you were still getting vectors, 6000ft is a long way from 14000. wow.
Its a good thing that controllers in other countries around the world don't have strong accents. Or terrain.
HUX is terrain critical, but it is by no means a complicated airport at all. The charts are painfully clear, even to a Non-AC driver. If you can get a reroute from Mexico City to the Oaxaca VOR and down to the HUX, that airway gets you in the lower 25 mile sector West of the 338 radial (i think... chart isn't in front of me), to 11400. If still IMC, crossing the VOR at 11400, and say 200kts with some flap makes it very simple and easy to descend on the teardrop to land on 25.
This incident is exactly why EGPWS (and the Escape Maneuver) exist so yay it did ITS job.
