NavAir Grounded in YYC???
broompusher
Post by broompusher »
I heard that NavAir's Calgary fleet has been grounded. I don't know if there's any truth to this, just wondering if anyone can confirm this or debunk it as rumor.
WTF, over
FuelLeak
Post by FuelLeak »
Nav got ramped by TC last week.
Sounds like TC pulled there A0C.
MRO
Post by MRO »
Its nothing huge just some trim indicators that were u/s and a few other details. They will be up and running by monday. Until then everyone else is covering for them.
CID
Post by CID »
Nothing "huge"? How many pilots out there would launch with trim indicators unservicable?
"Nothing "huge"? How many pilots out there would launch with trim indicators unservicable?"
If you need a needle to tell you your plane is trimmed out you've got other problems...
I can't remember the last time I looked at a trim indicator let alone used it to check if my plane was trimmed out... 3 pulls before blasting off and the rest of the way by feel...
" Nothing "huge"? How many pilots out there would launch with trim indicators unservicable? "
You gonna be out ramp checking again today after you get your paper work done CID? :mrgreen:
Cat
golden hawk
Post by golden hawk »
altiplano wrote:"Nothing "huge"? How many pilots out there would launch with trim indicators unservicable?"
I assume you've not flown anything over 12,500 lbs?
" I assume you've not flown anything over 12,500 lbs? "
Does Navair operate stuff over 12,500 now?
I bet B. would give you a raise in pay if you got back in your Navawhore and found a trim indicator that did not work and refused to fly it.....
Yeh, that would be interesting.
Just gotta love these discussions. :roll:
rigpiggy
Post by rigpiggy »
run it all the way forward then back 3 1/2 turns and adjust for the load. similiar thread here http://www.pprune.org/forums/showthread ... ght=navajo
ei ei owe
Post by ei ei owe »
I can't remember looking at trim indicators on most planes until recently. The one I'm on now has a visual check as part of the walkaround but seeing as NavAir doesn't operate those, it does not strike me as a huge deal. TC just looking for anything to close NavAir down. Haven't yet!
CID
Post by CID »
From what I know (I could be wrong) Nav Air operates MU-2s. A nasty airplane to suffer a trim run-away in. Or even worse, a mistrimmed take off. If I recall, the MU-2 had trim-in-motion lights installed by AD because of such problems. If the trim indication system doesn't work, what are the chances that the trim-in-motion indication system works?
So when you heros set your trims prior to takeoff don't you care if the trim indicator is actually displaying the truth? Even on a lowly 'ho?
On many advanced airplanes (yes even small ones) lack of trim indication is a serious issue. Its a no-go on pretty much any airplane. Any maintenance guy who signs off such an airplane is breaking the law. My guess that if such a defect was deferred it would be done with no paperwork trail so there is no way to nail the AME or to advise all the pilots of the problem.
In another thread we're discussing how some think that TC's purpose is to prevent accidents. Its a difficult task when the operators don't follow the rules themselves.
So again, TC gets blamed for grounding an unsafe airline but if the airplane made a smoking hole, TC would be blamed for neglect.
DragEraser
Post by DragEraser »
Don't they operate clapped out rice rockets too? I saw one of theirs in foreskinjohn i think it was. The stab boots were patches on top of patches on top of patches, some nice oil leaks, long cracks that haven't been stop-drilled, etc etc etc. Isn't it an art keeping the MU2 in the air? Wouldn't a trim indicator be important?
golden hawk
Cat Driver wrote:" I assume you've not flown anything over 12,500 lbs? "
Cat, altiplano didn't mention any specific aircraft. He said "3 pulls before blasting off and the rest of the way by feel...", which is hard to do with electric or hydraulic trims on larger aircraft. If I'm about to takeoff with an aircraft with these types of trims, I'd sure like an accurate gauge to tell me my trims are set properly.
ils09
Post by ils09 »
ok guys lets not make a big deal of this. Just dont let this thread become a NavAir bash. They are good guys with equipment that works just fine
KAG
Post by KAG »
Ever try a T/O with a King Air 100 out of trim and the out of trim horn not working? you'll wish you had taken that second to look.
Cheers.
Chase lifestyle not metal.
chipmunk
Post by chipmunk »
ils09 wrote:ok guys lets not make a big deal of this. Just dont let this thread become a NavAir bash. They are good guys with equipment that works just fine
So why are they grounded then?
2low
Post by 2low »
nm
ils09
Post by ils09 »
actually I know them and the equipment quite well. They are just somewhat adaptable. Do i agree with some stuff that they get away with? No. But bashing them isnt going to get anyone anywhere. They are our brothers too so maybe you should act like it and give them some support.
haligoner
Post by haligoner »
BWAHAHAHA!
Listening to you dumbasses talk about planes like the MU2 when you've never flown it is PAINFUL! I wonder if you even know, for example, that it doesn't have aileron trim, it has trim ailerons? Or even know what that means? In thousands of hours of flying them years ago, MU2's and Navajoes, I NEVER once set trim by looking at the indicator. I would exercise it full range first thing in the morning and then verify a neutral position on the walkaround. The trim indicator is only designed to get the trim into a very wide, general range and make sure it isn't at either limit, it's not some precision instrument that you're supposed to bet your life on! If you can't SEE that on a walkaround, you're an idiot, and if you do take off with either of these machines COMPLETELY out of trim, you're also an idiot, but it's still gonna be manageable - these simply are not transport-category a/c with such wide c of g, weight, and arm limits that trim is critical. Heresy you say? Certainly, it's good airmanship to operate in trim, but treating a trim indicator on a HO like it's a crucial item for dispatch is only displaying one's operational ignorance and inexperience. I know this attitude infuriates the legalists, but there you go. Write 'em up TC, technically they're in the wrong! ;)
Part of TC's problem is that they attract the "book-pilots" who think that every aircraft has the same operational requirements. Where the f^5k is the common sense?!
Golden Hawk :
My post was tounge in cheek.....
Just read between the lines in this comment I made..
"I bet B. would give you a raise in pay if you got back in your Navawhore and found a trim indicator that did not work and refused to fly it..... "
All I was doing was posing the delemma that a pilot might be faced with had a trim indicator in a Navajo suddenly quit working.....
I am not in any way advocating flying any airplane with a defect...the answer is to snag it and have maintenance make the decision whether to defer or fix.... however in the real world of flying things are not always black or white...sometimes young pilots are faced with decisions that are very hard for them to make...get the drift of where I was going with this....
Now this post poses another question.
How would TC find a unserviceable trim indicator on a ramp check?
Cat
ils09
Post by ils09 »
If u have a problem with Navair's Equipment maybe u should walk down the ramp have have a look at Dynamic
golden hawk
Agree Cat, there's two issues; idealism and realism.
Idealism - something doesn't work and if not no go and get praised for safety.
Realism - something doesn't work, and if no go pilot weighs safety vs. career (not usually taught in PDM or CRM)
Sad but true I guess.
As for B., don't know well enough to make that bet.
And, as for TC investigative skills.............no comment. :wink:
bee tee
Post by bee tee »
Trimming is for pussies!!!
tink
Post by tink »
Well I don't about the rest of u but I like trimmed pussies!!
bee tee
Post by bee tee »
Is "trimmed pussies" slang for well-groomed pilot?
