Piper
Moderators: Sulako, Right Seat Captain, lilfssister, North Shore, ahramin, sky's the limit, sepia
Re: SARON / SAMRA Feedback
Any one wrote SAMRA recently? I'm planning to write on Friday and would appreciate any new feedback. thanks!
AP
Any help with this question is greatly appreciated
decode the following FD
740538
ans: 240T @ 105kts temp ISA -5
detailed explanation on ea element please thank you.
740538
AP
See section 3.1.6 for decoding FDs of this nature.
https://flightplanning.navcanada.ca/aww ... cts-e.html
--Air to Ground Chemical Transfer Technician turned 3 Bar Switch Flicker and Flap Operator--
Thank you Adam. but what about the ISA -5? how did they get that figure?
FLis 240 so shouldn't the ISA temp be -33?
AP
The rule of thumb is to double the altitude and minus 15. Thus for FL240, 24x2=48. 48-15=33. The temperature in the example is -38, thus ISA -5.
Hope that clears things up.
Yes it does. just didn't do the last step after the calculation. thank you!
AP
Can anyone tell me what the 2 solid magenta lines beside the L (1005) mean please?
AP
Any help with this question is appreciated:
Shallow fog layer over the touchdown zone of the runway – slant visual range increase? does RVR A & B stay the same, Is prevailing visibility better or worse?
referenced the CAP GEN:
FROM CAP GEN: an approach is authorized whenever:
1. The lowest reported RVR for the runway is at or above minima, regardless of ground VIS
2. The RVR is reported to be fluctuating above and below minimum RVR
3. The ground vis is reported to be at least ¼ mile
4. The RVR for the runway is unavailable or not reported
5. ATS is informed that an aircraft is on a training flight and will conduct a planned missed approach.
based on TC answers I wasn't sure which one to choose.
AP
I can't seem to figure out how they are arriving at this answer. (see below image) ans highlighted in yellow
any help is greatly appreciated.
![Image]()
thank you
AP
thank you
AP
- IMG_2665.jpg (1.34 MiB) Viewed 3224 times
AP
C is between A and B
At FL240 temp would be (48-15) = 33degrees
A is 39 and B is 43 so C would be 41 which is ISA -8
Then wind
A is 75 and B 35 so C is 55 kts
Direction is same reasoning
Then wind
Wrote SAMRA 016 2 weeks go didn't pass by 2.5%
Studied harder and differently,wrote SAMRA 014 Friday and got 82.5%
I'd like to pesonally thanks LONER and GOOSE_68 for all their help, I really appreciate it.
Sources
ACWM
Aerocourse (met, radio nav, flt planning sections)
IFR workbook (met, radio nav, flt planning sections)
AIM for all the MET products
ATPL Aerocourse Binder (I didnt take the course, I borrowed a binder from someone that did)
my experience:
SAMRA 016
quite hard in the way that they state their answers ie. for HF Radio, 2 of the options were correct - not the most correct, they were simply both correct statements I chose short for day and long for night and got it right but there was also an option that said HF and LF.
VOR, RMI and HSI questions
more MET theory on cloud formation (ACWM helped me alot on this)
PROG chart
standard GFA, METAR, TAF, NOTAMS
function of PSR radar
change in wind from surface to boundary layer
effect of low level wind shear (know the air command + performance shear vs - perfermance shear and what it does to headwind/tailwind and A/S
GPS KLN 94 - showing CDI and asking what direction and how much to turn to get back on track
low level airway dimensions
standard ICING and T-storm stuff
flight plan rules
advantages of a/c lightning detection equip - main thing here is that it IS able to detect turbulence in clouds with little to no precip
GPS questions for ALT requirements
SAMRA014
answers easier to understand more straight forward
NO VOR, RMI OR HSI
SAT IR AND VIS IMAGES
WX RADAR display - asking what the hook meant (no option in answers for hail or turbulence)
Cockpit Management System - asking components that comprise the system
Effect of shallow ground fog over touchdown zone - answers RVR A&B the same, B better than A, Prevailing vis better ?
Pressure level temps
Effect of temp on indicated alt
Jet stream on sig wx and gfa - asking why the jet stream changed direction (i thought it was because of Coriolis force, its not)
nav equipment for NAT MNPS - one long range nav or one short range nav (i thought it was one long range, its not)
on course-parameters of an ILS system
GPS questions
equipment failure in controlled airspace - what do you do?
altimeter question - when its beyond 31.00 what do you do?
My advice is to know MET from ACMW, aerocourse work book helped alot and i was fortunate to have an aerocourse ATPL binder used from their course and that provided very good minute detail stuff that they put in the answers. if you overlook the minute/minor details you will get stuck in knowing which answer is the most correct one.
Any questions feel free to ask, i'll do my best to answer.
thanks
AP
Sources
ACWM
my experience:
SAMRA 016
PROG chart
flight plan rules
SAMRA014
NO VOR, RMI OR HSI
GPS questions
thanks
AP
AP
RVR A is at the threshold, RVR B is mid point. The assumption here is that the shallow fog IS ONLY over the touchdown zone, which means only RVR A is obstructed, not RVR. So the answer should be RVR A is less than RVR B.sagabwoy wrote: ↑Wed May 16, 2018 7:43 am Any help with this question is appreciated:
Re: Piper
Anyone know the answer for the following:
Microbursts due to downdrafts-what effects on A/C
A).INCREASE PERFORM ABOVE/BELOW GLIDESLOPE
B). DECREASE PERFORMANCE ABOVE/BELOW GLIDESLOPE
C). NOSE UP ATTITUDE ABOVE/BELOW GLIDESLOPE
D). NOSE DOWN ATTITUDE ABOVE/BELOW GLIDESLOPE
Pressure Gradient is the same, what causes wind to back and decrease?
a).friction due to surface cooling
b). reciprocal effects of winds aloft
Another question I cant find;
Effects of Auto pilot
a) centre of pressure
b) centre of gravity
