Ontario float bases
Bede
Ontario float bases
Post by Bede »
I need to ferry a floatplane from Kitchener to Thunder Bay. Other than Bar River, does anyone have any info where else that I could stop and pick up Avgas?
DCL415
Re: Ontario float bases
Post by DCL415 »
Azilda (White Water) operated By Sudbury Aviation outside of Sudbury
pirocco
Post by pirocco »
There is a float plane base around Orillia, on lake St-John (I think). It is close to the casino and there is also an airport.
Bede
Post by Bede »
Anything near Marathon or Gore Bay?
lionheart27
Post by lionheart27 »
100LL PN Humphrey Aviation Service 705-542-2590 CPX8
CNV7 Patridge Point Fuel & oil avbl May-Oct 13-17Z‡ Mon-Fri, O/T PN
CPJ9
Manitowaning Seaplane Base only mogas
Algoma Mills private Lauzon Aviation Co Ltd. 705-849-2389 Reg PPR?
Carry Jerry cans and claim limited access!!!
"Traveling through hyperspace ain't like dusting crops boy"
"Up the Irons"
CLguy
Post by CLguy »
Wawa has a couple of float bases. Geraldton has fuel. You land on Hutchison Lk beside the airport and they will bring the bowser and top you up.
Bede
Post by Bede »
Awesome, thanks guys!
sdp
Post by sdp »
I’ve done that trip twice but from Gatineau. I stoped at azilda(Sudbury aviation). Then up to hawk junction just east of Wawa. Hawk air. Then to Gerlton.
Bede
Post by Bede »
Can someone get me some more info on fuel in wawa. Watson's only has jet and Air Dale phone number doesn't work.
Bede
Post by Bede »
Hawk junction phone doesn't work either.
matt17
Post by matt17 »
https://www.hawkair.com
This is the website for the operation on Hawk Lake. I believe they still operate a piston beaver and C180 so should have avgas. Not sure on sales though.
I am pretty sure Forde Lake Air out of hornepayne will sell gas with prior notice. At least they did the past few years. Not sure if this will help for flight planning.
Lotro
Post by Lotro »
Air Dale is no longer operating, so that base in Wawa is not active. Similarly, NV7 (Partridge Point) is closed as well. Hawk Air in Wawa is your only option there.
If you're passing through the Sault area, the Bushplane should work, or PM me and I'll help you out.
sdp
Post by sdp »
Hawk air is who you want to call. They are on hawk lake.
