Skylease Cargo 747 Runway Overrun YHZ Nov 7, 2018
JBI
Post by JBI »
https://www.cbc.ca/news/canada/nova-sco ... -1.4895103
Crew of 5 treated for minor injuries. Aircraft in one piece, but very damaged off the end of 32
https://www.thechronicleherald.ca/news/ ... rt-257275/
Jet Jockey
Re: Skylease Cargo 747 Runway Overrun YHZ Nov 7, 2018
Post by Jet Jockey »
Glad everyone is OK but that aircraft is most likely a write-off.
CL-Skadoo!
Post by CL-Skadoo! »
I'd say so...
Roadrunnersmother
Post by Roadrunnersmother »
Whoever is spokesperson for airport authority should be fired.
Aircraft went off end of RW14 which is near the golf course, not RW32 that the airport spokesperson said.
How can you get a job as spokesperson with little knowledge.
rigpiggy
Post by rigpiggy »
Anybody have the wx for the accident time?
lostaviator
Post by lostaviator »
rigpiggy wrote: Wed Nov 07, 2018 7:35 am Anybody have the wx for the accident time?
If you google metar history there’s a website that stores every report.
From a speci minutes after the accident:
230-11-g18. 8sm. -RA BR. SCT005. BKN012. 13/13
tbayav8er
Post by tbayav8er »
I know 23 is under construction and most of the approaches are unusable, but I wonder what the LNAV minimums are. ~8500 ft available for landing on 23 even with the construction and 18 kts on the nose as opposed to 7500' and no headwind.
Glad no one got badly injured!
Gilles Hudicourt
Post by Gilles Hudicourt »
Does anyone have the Notamns ? It could shed light on the choice of runway.....
Gilles Hudicourt
tbayav8er wrote: Wed Nov 07, 2018 7:56 am but I wonder what the LNAV minimums are. ~8500 ft available for landing on 23 even with the construction and 18 kts on the nose as opposed to 7500' and no headwind
I checked the plates. There are many variables, don’t know what their equipment and ops specs allow. Plus, one would also need to see the Notams, in case these modified the published minimums.
lostaviator
Approaches on 23 are very limited right now.
With magnetic variation from the metar winds, 32 was their next best choice.
lostaviator
And it’s not like our notams are ever misleading.... seeing rnav 23 LNAV/VNAV not auth piled in there with all the others, they could have missed the fact the LNAV mins were still useable.
I don’t get why this airport waited till fall to do runway construction when all the fall windstorms show up. Now there won’t likely be any ILS approaches for a week or 2 till they clean up that giant mess.
lostaviator
With all the horrible reporting (runway 2???), I thought they landed on 32, but it was 14. Little bit of a tail wind, wet runway, big plane.
porcsord
Post by porcsord »
You're all sick. No mention of the poor lobsters, probably thousands of them.
J31
Post by J31 »
porcsord wrote: Wed Nov 07, 2018 9:50 am You're all sick. No mention of the poor lobsters, probably thousands of them.
I'm sure they will make it to China dishes.....may just be a bit more expensive. :smt040
Post by North Shore »
My reading of the story says that the '47 was there to pick up the lobsters...so they just got a temporary reprieve..
Happiness is V1 at Thompson!
Victory
Post by Victory »
Where is Halifax storing all these wrecks? Do they cut them up and ship them out by truck pretty quickly?
Old fella
Post by Old fella »
‘47 Cargo haulers having bit of a rough time in YHZ past number of years. This one and MK airlines 2004 sadly fatal for the entire crew.
I'm sorry, but someone has to say it.
Variable tailwinds on final.
short bus
Post by short bus »
I'm surprised It took that long
telex
Post by telex »
photofly wrote: Wed Nov 07, 2018 2:24 pm I'm sorry, but someone has to say it.
Re: Stalls into a headwind or Tailwind
Zaibatsu wrote: ↑Sat Oct 27, 2018 10:56 pm
Was it a variable tailwind?
Because that will definitely negatively affect the stall characteristics.
It’s perhaps one of the deadliest things we deal with in aviation.
A tailwind? Wha?
NOW I get it! haha
It takes a lot to accept that mantle of responsibility - good on you Photofly!
HiFlyChick
Post by HiFlyChick »
The HIAA FB page said (and still says) runway 32 - hard to believe they could get it so wrong...
I wonder if they were doing the ILS for 14 because they didn't have RNAV capability...?
Didn't see the wx at the time of the "hard landing" (yep, the evening news actually called it that - we don't have accidents at YHZ, just hard landings), but I looked at the METARS a few hours later and it still had the one for 10z (about 45 min after accident):
METAR CYHZ 071200Z 23012KT 10SM BKN008 BKN014 OVC023 12/12 A2969 RMK SF5SC2SC1 SLP058 DENSITY ALT 600FT=
SPECI CYHZ 071137Z 23012KT 10SM BKN008 OVC014 12/12 A2969 RMK SF6SC2 SLP058 DENSITY ALT 600FT=
METAR CYHZ 071100Z 22013G18KT 8SM -DZ OVC008 13/13 A2967 RMK ST8 SLP050 DENSITY ALT 600FT=
SPECI CYHZ 071054Z 22012G19KT 8SM -DZ OVC008 13/13 A2967 RMK ST8 SLP051 DENSITY ALT 600FT=
SPECI CYHZ 071031Z 23016G21KT 10SM -DZ SCT009 OVC015 13/13 A2967 RMK SF4SC4 SLP051 DENSITY ALT 700FT=
SPECI CYHZ 071023Z 23013KT 12SM SCT007 SCT015 BKN070 OVC090 13/13 A2967 RMK SF3SC1AC3AC1 SLP050 DENSITY ALT 700FT=
METAR CYHZ 071000Z 23012G19KT 12SM -RA SCT006 BKN036 OVC070 13/13 A2967 RMK SF3SC2AC3 SLP051 DENSITY ALT 700FT=
The ILS for 23 is down, so if they couldn't do the RNAV, and that SCT 006 was BKN, the ILS 14 was all they had (except for diverting elsewhere - too bad they didn't take that option :( )
HiFlyChick
Inverted2 wrote: Wed Nov 07, 2018 8:38 am I don’t get why this airport waited till fall to do runway construction when all the fall windstorms show up. Now there won’t likely be any ILS approaches for a week or 2 till they clean up that giant mess.
They've been working on taxiways since the summer, and the runway for a while, too (can't recall exactly when they started, though). Earlier than that and they're into fog season, which tends to be more of a problem than the fall winds - it's just been windier this year than usual (or should I say there's been more windy days).
Jet Jockey
At the time of the landing they had an almost direct tailwind at 16kts gusting 21kts as reported by the tower on final.
The tower even questioned them with these winds if they were OK to land on RWY 14.
