There is a steady stream of retirements, company is 30 years old...
Hiring?
Re: Hiring?
Re: Hiring?
Last I've checked in was mostly YYZ positions ? Roughly how long until you're able to hold YUL ?
Re: Hiring?
Can anyone shed some light on commuting from Vancouver-specifically if they do block days together for a commuter type schedule? I would prefer to stay on the West Coast but want to make AT my next goal. Any input on current AT commuters living on the West Coast would be appreciated. PM me also if you like-thanks!
Re: Hiring?
Air Canada has up to 16 flights a day, at least half the time they are all full and you won't get on.FOD_Vacuum wrote: ↑Mon Nov 19, 2018 11:54 am Can anyone shed some light on commuting from Vancouver-specifically if they do block days together for a commuter type schedule? I would prefer to stay on the West Coast but want to make AT my next goal. Any input on current AT commuters living on the West Coast would be appreciated. PM me also if you like-thanks!
Westjet has up to 9 flights a day, most of the time there is room.
AT has a flight every day in the summer, winter hit and miss. Flights are usually full but you can jumpseat.
Schedule is seniority bid. If you are at the top of the list, you can pick and choose whatever schedule you want. If you are at the bottom of the list you get whatever is left over. In the summer it's mostly 4-6 day pairings, expect to do 4 of them per month spread out over the month so of your 12 days off you can expect to spend at least 4 of them traveling to and from YYZ. In the winter there is a mix of Europe pairings, domestic pairings, and turns from YYZ. At the bottom of the list you can expect a 8-12 turns a month spread out over the month so going back and forth between YVR-YYZ becomes problematic. Do you spend a day traveling home and back just to have a day at home or do you just spend 2 days in YYZ. Anyone in the bottom half of the list can expect to be reserve one month out of every 2 or 3 which means you will need to be sitting in YYZ for 18-19 days in the month. Bid AM reserve so that you only lose a day at the beginning of each period instead of at both ends.
If you want to make AT your goal, a move to YUL or at least YYZ would be in your best interest. If you want to stay on the West Coast, choosing the only international airline in Canada that does not have a YVR base would not be in your best interest, there are much better options.
Re: Hiring?
Widely variable. In some classes it's under 2 years, others over 5. Then you have to bid back to YYZ for an upgrade. I would guess anyone coming on property today should be prepared to spend at least 50% of their career commuting to YYZ.
Re: Hiring?
Good info! I screwed up by taking a commuting job once and not looking to make that mistake again.
Re: Hiring?
What about WB flying? How many years to the FO spot on WB? How long does it normally take to upgrade?
Re: Hiring?
The majority of new hires are WB from day one. WB/NB positions are determined as per the company requirements at time of hire. It's flat pay for the first 2 years anyway. Within 2 years most of the company will be CCQ and therefore flying a mix of WB/NB each month.
Re: Hiring?
What is CCQ?
Thanks,
Thanks,
ahramin wrote: ↑Thu Nov 29, 2018 10:59 am The majority of new hires are WB from day one. WB/NB positions are determined as per the company requirements at time of hire. It's flat pay for the first 2 years anyway. Within 2 years most of the company will be CCQ and therefore flying a mix of WB/NB each month.
Re: Hiring?
Being ccq means being cross trained on the 330 and 320 family.
I started in august on the 330 , but i m already marked down as 330 320 so i d assume in the next fall i will train on the 321
Andy
Andy
Re: Hiring?
Last edited by indieadventurer on Thu Dec 27, 2018 6:09 am, edited 1 time in total.
Re: Hiring?
Re: Hiring?
17 new hires in February... A mix of 320 and 330. Good times, good times!
Re: Hiring?
Any idea when the posting will be back up or if they are looking for guys this Spring at all?
Re: Hiring?
The posting is back up, and they've dropped the "bilingualism is an asset" from the ad!
https://www.transat.com/en-CA/corporate ... ingId=4105
Re: Hiring?
They still ask for it....In the french section...
https://www.transat.com/fr-CA/corporati ... ingId=4105
Re: Hiring?
Is there hiring for YUL (like ever?) or do you have to go through YYZ to get tu YUL?
58
58
