How to get rid of that autopilot
"C-GMLS, a privately registered Cessna 340A aircraft, was conducting an approach at Ponoka Industrial (Labrie Field) (CEH3), AB with only the pilot on board. The pilot missed the first approach due to autopilot malfunction issues, and decided to do a forced landing during the go-around due to the autopilot that would not disconnect as needed. As the forced landing in a field was executed, the aircraft struck a tree during the slide. The aircraft was substantially damaged, and the pilot walked away with a serious injury."
I wonder if simply turning off the electrics would possibly save the day strictly in terms of regaining control of the aircraft.
Any opinions?
Any opinions?
Bacunayagua
Re: How to get rid of that autopilot
Interesting situation.
I always make it a point of familiarizing myself with the location of the more "critical" CBs, incase simply turning off the unit/ electronics isn't doing the job. That being said, I never found it difficult to overpower the A/P servos in small planes. As a matter of fact, I think it is part of the certification process that they be easily overpowered, no? Maybe someone can correct me on that. I remember when I used to fly similar sized/weight Cessnas, moving the controls around when the A/P was engaged was part of the A/P systems check while still on the ground.
I believe turning off the avionics master would do the job. Quick and easy.
TeePeeCreeper
Yep, loosing all your primary flight desplays rather than disconnecting the AP or pulling the AP breaker sounds like a GREAT idea while in IMC!
A Cessna cabin class twin crashed because the pilot could not turn the autopilot off!pelmet wrote: ↑Thu Nov 29, 2018 12:47 pm "C-GMLS, a privately registered Cessna 340A aircraft, was conducting an approach at Ponoka Industrial (Labrie Field) (CEH3), AB with only the pilot on board. The pilot missed the first approach due to autopilot malfunction issues, and decided to do a forced landing during the go-around due to the autopilot that would not disconnect as needed. As the forced landing in a field was executed, the aircraft struck a tree during the slide. The aircraft was substantially damaged, and the pilot walked away with a serious injury."
Any opinions?
I think the issue was mostly a lack of knowledge and poor or no training.
There are at least 2 foolproof ways of disconnecting an autopilot. One is a switch on the autopilot controller that is marked OFF. Then there is the big red button on the control column marked OFF that when pushed, shuts off the autopilot. Sounds to me the pilot needs some Special Hight Intensity Training (SHIT) if you get my drift.
In the Ho you just give it a sharp yank and the AP disconnects. Not good for the system but in an emergency it would do the trick.Bacunayagua wrote: ↑Thu Nov 29, 2018 1:00 pm Interesting situation.
It probably saved his life.
I shudder to think of a private pilot staying on instruments hand flying an aircraft while fighting a runaway autopilot.
switchflicker
I think we sued to call that the B R B.oldtimer wrote: ↑Sat Dec 01, 2018 9:25 pm There are at least 2 foolproof ways of disconnecting an autopilot. One is a switch on the autopilot controller that is marked OFF. Then there is the big red button on the control column marked OFF that when pushed, shuts off the autopilot. Sounds to me the pilot needs some Special Hight Intensity Training (SHIT) if you get my drift.
"I'd rather have it and not need than to need it and not have it" Capt. Augustus McCrae.
That's a head scratcher. Couldn't disconnect the autopilot...so he tried to land in a field? Give that man a drug test. Give him two just to be sure.
Last summer my Cherokee trim switch decided to short out and transit to full pitch up while on climb out. Although I could control the aircraft, it isn't something I'd be able to do for very long. The red button made life much easier as I turned around to land.
Edit for detail.
While the switch was smoking I couldn't physically move the trim wheel against the force of the motor. With my master shut off I was able to manipulate my trim wheel and land normally.
Edit for detail.
Interesting experience. I wonder if an autopilot disconnect switch could have some sort of malfunction like this and not disconnect. Or some single point failure closer to the autopilot itself.FlyGy wrote: ↑Fri Dec 07, 2018 7:25 am Last summer my Cherokee trim switch decided to short out and transit to full pitch up while on climb out. Although I could control the aircraft, it isn't something I'd be able to do for very long. The red button made life much easier as I turned around to land.
Any avionics types around here?
