How many seconds would you have to identify the issue and perform those actions if they happen at 1000 AGL?
Ethiopian Airlines: 'No survivors' on crashed Boeing 737 max
Re: Ethiopian Airlines: 'No survivors' on crashed Boeing 737 max
https://www.ctvnews.ca/mobile/business/ ... -1.4330994
Boeing makes a great product and I've flown on many types but until they get some more info, I would err on the side of caution and not fly it. Let's have garneau put his money where his mouth is.
Most of Indonesia and China has stopped at this time, as well as a couple others.
Why would the MAX not have the stab trim brake feature of earlier Boeings, that braked the stab trim as soon as the control column was moved in the opposite direction to trimming?? Also Does the MAX have a warning for stab out of trim condition?
China has most likely made this move as an F-U to the USA.Heliian wrote: ↑Mon Mar 11, 2019 3:42 pm https://www.ctvnews.ca/mobile/business/ ... -1.4330994
As for why Canada hasn’t suspended MAX ops, why shouldn’t we follow the advice of Boeing/NTSB?
As for the safety record of Ethiopian Airlines:
As of March 2019, the Aviation Safety Network records 64 accidents/incidents for Ethiopian Airlines that total 459 fatalities since 1965,[1] plus six accidents for Ethiopian Air Lines, the airline’s former name.[2] Since July 1948, the company wrote off 36 aircraft, including three Boeing 707s, three Boeing 737s, one Boeing 767, two Douglas DC-3s, two Douglas DC-6, one de Havilland Canada DHC-5 Buffalo, two de Havilland Canada DHC-6 Twin Otters, 21 subtypes of the Douglas C-47, one Lockheed L-749 Constellation and one Lockheed L-100 Hercules.
“A sociopath is a term used to describe someone who has antisocial personality disorder (ASPD). People with ASPD can't understand others' feelings. They'll often break rules or make impulsive decisions without feeling guilty for the harm they cause”tbaylx wrote: ↑Mon Mar 11, 2019 1:09 pmYup that's what I was doing, not replying to another post on the same subject. Chilling, simply callous and chilling.GRK2 wrote: ↑Mon Mar 11, 2019 9:24 amLet me put it more simple terms there Tbay...this isn't the place for your investment tips...and yes, to tell us all how smart you think you are by posting your stock buying idea on an accident thread is purely chilling. Take it outside buddy, it doesn't belong here.
"Stand-by, I'm inverted"
That pretty much describes you over the last few months. Seek help.mbav8r wrote: ↑Mon Mar 11, 2019 4:50 pm“A sociopath is a term used to describe someone who has antisocial personality disorder (ASPD). People with ASPD can't understand others' feelings. They'll often break rules or make impulsive decisions without feeling guilty for the harm they cause”tbaylx wrote: ↑Mon Mar 11, 2019 1:09 pmYup that's what I was doing, not replying to another post on the same subject. Chilling, simply callous and chilling.GRK2 wrote: ↑Mon Mar 11, 2019 9:24 am
I saw a caption on a news website of the plane's VS. It was erratic but I also noticed they fought the plane for about 3 minutes in the data shown. Is there any indications the MCAS has activated? Or is aggressive pitch down the only indication?digits_ wrote: ↑Mon Mar 11, 2019 3:22 pmHow many seconds would you have to identify the issue and perform those actions if they happen at 1000 AGL?
I’m positive that if the two of us were to be analyzed by a psychiatrist, one of us would be considered a sociopath, I’m also positive it wouldn’t be me but you keep deflecting, seems to work for you.tbaylx wrote: ↑Mon Mar 11, 2019 5:07 pmThat pretty much describes you over the last few months. Seek help.
The 737 Max and NG have control column trim cut-out switches. Trimming nose down and pull back? Electric trim will stop.
Once you relax the controls though the trimming (either person or FCC commanded) will begin again.
There is an interrupt if the column is pulled in the opposite direction. Apparently it doesn’t function under these circumstances. There is a light for stab out of trim. With the flaps retracted the trim moves relatively slowly.
From another forum.
“And Boeing have still not explained the logic of of a pseudo-stick-push that keeps operating again and again and again, until you get full forward trim. Have you tried this MCAS-trim-runaway in the sim? According to the sim, the aircraft is only just about controllable with two gorillas hauling back in unison, with both feet up on the foot-bar and hauling about 40 kg pressure on each stick. And that was in level flight with the CofG in the central position. Ok, now try a recovery from a stall-dive, with a forward CofG, with 20º nose down pitch, and with the speed rapidly increasing to 250 kt. It is absolutely impossible - you are doomed. And doomed by an anti-stall system that is supposed to save you. But who in the world would want to recover from a stall, with the trim-stabiliser set fully forward? Who thought that ine up? The stabiliser is more powerful than the elevator, and will take you straight down to terra-firma. Heck, even the Wright Brothers knew not to design something like that.”
[/quote]
Hopefully you recognize the problem before full nose down trim and select the cutout switch’s off as per the memory item. Then take the handle out of the wheel and trim it back manually.
With all the other *unknown* modifications to the 737 systems, perhaps the stab trim cutout switch position can be overridden by the MCAS system. The system knowledge I have tells me no, but then again, who knows anymore... Because Boeing doesn't want us knowing the systems.
New personal SOP on this thing is autopilot on at 400 agl prior to flap retraction altitude.
It may be that both the FAA and Transport Canada are complicit in this B737-800 MAX disaster. Especially IF the investigation brings to light that MCAS played a roll in the accident.
Neither the FAA nor TCCA FSB OEB reports say a word about or have an abbreviation referring to MCAS.
If the MAX is the only version of the 737 with MCAS, then why wasn't it raised in the OEB reports with an accompanying recommendation for specific training?
The first link in a chain?
I believe the Lion Air accident prompted Boeing to initiate pilot awareness training once it was pointed out that MCAS was a new system but not included in pilot training material which was an omission on their part. Are we to believe Boeing didn't mention MCAS to MAX crews prior to entry into service? Apparently.
The second link in the chain?
If the Ethiopian crew received this awareness training, wouldn't they have been better prepared for an MCAS event than the Lion Air crew?
The third link in the chain?
I think it would be prudent to ground the MAX fleets UFN.
As the saying goes, never two without three.
Gino Under
Gino Under
All good points. I think there were a lot of "Educated" guesses made by Boeing after the Lion air incident. There is a system/systems not functioning the way they were designed too and the checklist revision came out before any concrete evidence was produced.Gino Under wrote: ↑Mon Mar 11, 2019 6:05 pm It may be that both the FAA and Transport Canada are complicit in this B737-800 MAX disaster. Especially IF the investigation brings to light that MCAS played a roll in the accident.
Gino Under
Also, the country that knows the most about the first incident (Indonesia), has grounded their max fleet. That alone is enough for me to think we need to hit pause on these planes for a bit.
The Lion air accident will have the MCAS system as a factor. It was most definitely active during that flight - however a number of things stand out in that one.
First the last 3 legs had the same problem and each time the crew used the stab cutout switches to stop the trim.
Second - the crew got the stick shaker right at rotation and continued.
Third - they never used the cutout switches.
Forth - the crew actually lost control when the retracted the flaps....they then re-extended to flaps 5 and the system cut out as designed. Then then selected the flaps back up and fought the airplane till the end of the recording. Obviously the maintenance crew also failed in rectifying the problem.
You can take this with a grain of salt but there are some reports that witnesses to the Ehiopian flight saw smoke and debris coming from the aircraft while it swerved around the sky before diving into the ground. I would be hesitant to say this is the same issue.
If this turns out to be the same as the Lion air flight then there may be a fault or improvement Boeing could make in the system - but it is not a situation which is unrecoverable.
- confusedalot
I too would be hesitant at pointing fingers right now.
Flew the NG's, did sim evaluation on the MAX, after talking to my american airlines buddy who flies both, it is pretty darn clear that every single 737 pilot around the world is spring loaded to hitting those disable switches before you can say ''huh?''.
There is more to this story. Which nobody knows yet.
- fruitloops
https://www.cnbc.com/2019/03/11/faa-boe ... orthy.html
The video on this page has some interesting commentary
https://www.cbc.ca/news/world/boeing-up ... -1.5052471
Software upgrade on the way.
I’d bet there a few Sleepless in Seattle tonight.
Growing list of countries/Airlines who have grounded the aircraft:-
https://www.scmp.com/news/world/united- ... ill-flying
https://www.flightglobal.com/news/artic ... re-456540/Capt. Underpants wrote: ↑Mon Mar 11, 2019 9:35 amMCAS was used to certify the flight envelope limitations on the MAX. You don't just "turn it off" and carry on as if nothing happened. Any changes to the system would require re-certification prior to release to the industry.tbaylx wrote: ↑Mon Mar 11, 2019 7:47 am Lets assume worst case scenario and its a faulty AOA sensor and a mishandled MCAS response. Emergency AD issued changing the FCC software and removing the MCAS trim inputs and the fleet is flying again. Long term it gets fixed with software or addition of a third AOA sensor. The aircraft will continue to be bought and put into service, same as the 787 after the battery issues got fixed.
There's the software update and upcoming AD.
- rookiepilot
UK just halted MAX flights within it's airspace.
